Author Topic: LT3081 in series to charge/balance batteries in series  (Read 2888 times)
Offline dweeb99Topic starter
  • Country: ie
« on: January 27, 2020, 12:25:48 am »
Has anybody tried LT3081 regulators in series each one charging each battery independently in a series of batteries?
Something like a simplified version of the same type of battery charging circuit using TL431 here
The LT3081 floating regulator has 1.5A output which avoids the need for external transistor to boost current as is used in the TL431 circuit and the Imon pin senses the current draw/5000 & regulates output current proportional to the current draw of the battery while charging. It has reverse battery & reverse current protection.
I'm looking to go this route mainly because I may connect to some of the series batteries for different & multiple output voltages & wanted to keep each battery balanced & fully charged using this circuit
Am I missing anything in my thinking?
« Last Edit: January 27, 2020, 12:32:56 am by dweeb99 »
Offline David Hess
  • DavidH
Re: LT3081 in series to charge/balance batteries in series
« Reply #1 on: January 27, 2020, 09:50:28 am »
That could be done but it would require a lot of separate floating supplies and LT3081s are not cheap.  The floating supplies could come from an inverter or flyback regulator.
It would be simpler to use one LT3081 and power supply with a charge balancing circuit capable of supplying the separate loads.
  • Country: ie
« Reply #2 on: January 27, 2020, 10:40:13 am »
My thought was that LT3081 is a floating regulator just like TL431 so no ground pin & therefore could be used connected in series with each LT3081 charging its equivalent battery in the series - just like with TL431.
AFAIK, there's no need for multiple floating supplies in this scenario.
I'm not too bothered about the price of the LT3081s as I already have a stock of them.
The issue with using one LT3081 across the series of batteries is that I may want to pull voltage output @ ~1A from any of the middle batteries in the series (i.e a different voltage output) & I haven't seen a balance circuit capable of keeping the batteries in balance with that sort of current draw. Maybe I'm wrong?
« Last Edit: January 27, 2020, 01:12:34 pm by dweeb99 »
Offline hli
« Reply #3 on: January 27, 2020, 01:30:07 pm »
In the circuit shown, the TL431 parts do not act as a traditional voltage regulator. These circuits are used for balancing the charge between the cells. In a nutshell, they word as a shunt regulator - when a cell reaches certain voltage, each of the balancers shunts current away from the cell (its then flowing through the transistors). So the cell is not charged further, but all the other ones can still be charged.
AFAICS this cannot be done by a LT3081.
  • Country: ie
« Reply #4 on: January 27, 2020, 01:42:51 pm »
Sorry, wrong diagram - should be this one which shows a series TL431 used as floating voltage regulator to charge batteries in series - essentially it cuts off the charging when the cell reaches a set voltage - explanation of circuit here https://keithwelliott.com/2016/07/17/openadr-battery-charger-simulation/
Offline David Hess
  • DavidH
« Reply #5 on: January 28, 2020, 03:20:47 am »
The TL431s are being used as power shunt regulators so they only see the voltage across them.  Essentially they are just high power precision zener diodes.  You might be able to wire an LT3081 to be a power shunt regulator but the result will not be what you want.
No, there isn't, but it is the easiest way.
If LT3081s are used then each has a ground (really common) reference which is either the ground (common) of all of the cells or just the one cell that it is attached to.  But the input voltage for each LT3081 has to come from somewhere and if there is only one power supply, then it will be referenced to the ground (common) of all of the cells.  The power supply might have multiple outputs to supply each LT3081 so each operates with a minimum of power dissipation but there is another problem.
The charging current through the top cells flows through the bottom cells.  This would be acceptable if there was always a load on the bottom cells but without a load, cell imbalance is likely unlike with the case of multiple TL431 shunt regulators individually protecting each cell.  The LT3081 has no ability to sink current like a TL431 or any shunt regulator.
The multiple floating power supply suggestion solves that by referencing each floating supply output to only the individual cell that it is charging.
I have not seen a balance circuit capable of high currents either but that is just because there has been no need for it.  An LT3081 is half of a linear balancing circuit; it just can only balance in one way.  A micropower operational amplifier with a pair of power transistors can easily drive an amp or more of balancing current between two cells while drawing nothing when no balancing is required.  The transistors (1) only have one cell worth of voltage across them so at 1 amp, power a little less than 4 watts which is not difficult to handle.
Or keep the TL431 power shunt regulator string for its simplicity because it will do the same thing.  The operational amplifier way might be perfered for lower quiescent current draw.
(1) This might be a good application for complementary NPN/PNP Darlington pairs.
  • Country: ie
« Reply #6 on: January 28, 2020, 01:49:03 pm »
Thanks  David
Yes, as far as I understand, the TL431s act as adjustable precision zeners which turn on the PNP transistor at the set voltage thus shunting current past the battery cell.
I'm wondering if there is any issue with LT3081s acting as simple floating voltage regulators bringing each battery cell in the series up to the voltage set by Rset?
« Last Edit: January 28, 2020, 11:54:38 pm by dweeb99 »
Offline Bucko
  • Country: si
« Reply #7 on: July 19, 2022, 07:02:34 am »
Hello, I made the circuit according to the schematic from the first post (dweeb99).
When I connect the circuit to the power supply, the LED always lights up.
Does anyone have an idea what could be wrong?
I have 4S6P Li-ion battery pack (18650).
Best regards
