I have a couple PCI DAQ cards from National Instruments that I would like to get working on a newer PCI-E desktop. Does anyone here have experience with the various adapters available? I'm looking to avoid the bad ones. Cost isn't the most important factor. It just needs to work. Probably a dual slot or higher. Windows 10 and Linux.
Thank you,
RJ
Something like the attached, or better.
I also found this one. It uses a DVI cable that Startech says will work with 10-20 Ft cables. Anyone with experience with any PCIE to PCI adapters like this or similar?
I could probably buy an entire PC for the price of this one but space and form-factor are better with the Startech, if it works...
From Amazon: "StarTech.com PCI Express to 4 Slot PCI Expansion System - PCIeo PCI Expansion Box - External PCI Slot - PCI Expansion Chassis (PEX2PCI4) Black"
