found this interesting looking item
was advertised as
Lam RESEARCH / EXCELITE PAX-10 Precision-Aligned Pulsed Xenon Light Source
![](https://2.bp.blogspot.com/-dRE5_U6Alb0/XNxQgDHbbRI/AAAAAAAAC68/T7YqUtghVy0bln-wU0MgkAGnR3qIvyBVQCLcBGAs/s320/IMG_5519.JPG)
what i saw was a setup of a light source and a spectrometer
had to find out what is it even if it was a bit expensive
and so..
PAX-10 by excelitas xenon 10w light source
![](https://1.bp.blogspot.com/-fvtn2C_2DlA/XNxROlRHtJI/AAAAAAAAC7Q/r68wbomjM2sJHyCBK6WbIc0Qut3DclsUgCLcBGAs/s320/IMG_5521.JPG)
next was to find out what was the other unit, started to search some of
the numbers and found some horiba / jobin yvon spectrometer images that look similar
still needed to find the specific model, i think it is the VS-7000-CCD
but the specific model configuration specs is yet unknown
![](https://2.bp.blogspot.com/-lRHP0KkI7H4/XNxRNu347zI/AAAAAAAAC7M/DzzlHnnSs5MHcxXWQGU5Plj8g6FhR-mOACLcBGAs/s320/IMG_5515.JPG)
looks like the power is shared between the light source and spectrometer,
signal is a DB9 that goes to the xenon light source and continue to the spectrometer,
usb belongs to the spectrometer
![](https://4.bp.blogspot.com/-wj0F25j5qbE/XNxRQTXBe4I/AAAAAAAAC7g/hx33BlvbASQGGdPGYauw1XdSjuv1l69kgCLcBGAs/s320/IMG_5526.JPG)
pinouts:
PAX-10:
pin 1 -- Vin
pin 2 -- Vin
pin 4 -- Trigger -
pin 5 -- Trigger +
pin 6 -- Gnd
pin 7 -- Gnd
Spectrometer:
pin 3 -- to main unit DB9 (pinout 3)
pin 5 -- Trigger +
pin 9 -- Trigger -
so looks like there is an option to trigger both the spectrometer
and the light source from the main DB9
![](https://4.bp.blogspot.com/-cSCz-M1U2qc/XNxRPLLZtiI/AAAAAAAAC7U/_M4CENTH-bYE7ATNESLlAmKzjXmHvX6vwCLcBGAs/s320/IMG_5522.JPG)
a close look at the fiber optic tip
xenon light source is the outer fiber bundle
while the inner fiber goes to the spectrometer
![](https://4.bp.blogspot.com/-_m-4axPvM-Q/XNxXvpLuJOI/AAAAAAAAC8M/fGV7VpwinnAoqCyepR_JiBDyekFy_1zjgCLcBGAs/s320/IMG_5514.JPG)
next step was to find the power needs which i knew was somewhere between 11-28v
just because it was written on the PAX-10
![](https://4.bp.blogspot.com/-CtGzfIn7oXM/XNxRPGyH4tI/AAAAAAAAC7c/87ixpV5yvM87cSASMK_DVuFG24onHhJFwCLcBGAs/s320/IMG_5525.JPG)
first thing is to define the power polarity
next was starting at 11v and go up until ill find some signs from the usb
at 23v i saw a green led light, rounded it to 24v as there isn't much difference
in between if you consider the power tolerance and 24 looks also more logical then 23
usb details:
idVendor 0x0c9b Jobin Yvon, Inc.
idProduct 0x000e
![](https://3.bp.blogspot.com/-49zwmXe7gig/XNxV0GFHXZI/AAAAAAAAC8A/sQtotCXlCo4-0_V_Ut4QAFn2jOCbQsvowCLcBGAs/s320/IMG_5524%2B%25281%2529.JPG)
next step was checking the light source trigger was specify as 5v
![](https://3.bp.blogspot.com/-kQr8A39Z1yg/XNxRQiUv2dI/AAAAAAAAC7k/0HB31cpTs00CzwVz-1PL2Oq8rtDMhPapgCLcBGAs/s320/IMG_5530.JPG)
looks like everything is working ,cool
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
wasn't a complete waste of money
might even find a good use to this setup even if not in its current configuration
first thing will be to replace the power plug with a more common one
still need to source the spectrometer driver so any help will be appreciated
to this moment didn't get any answer from Horiba / Lam RESEARCH
