Author Topic: low pass filter noise ? best is passive or base on a op amp ?  (Read 314 times)
Offline OverspeedTopic starter
« on: August 12, 2024, 07:41:23 am »
Hello
Some op amplifier provide very low noise but when a low pass filter is added that generate noise ( after amplification OK ) SO :
Does there is designs requirements to built a low noise filter as a low pass 150 Hz filter ?
A common way is to fit a passive resistor + cap at the op amp output as described in Analog / TI docs
Regards
OS
« Last Edit: August 12, 2024, 10:31:16 am by Overspeed »
Offline Benta
Re: low pass filter noise ? best is passive or base on a op amp ?
« Reply #1 on: August 12, 2024, 10:48:23 am »
Noise has much more to do with which opamp you select than anything else.
The output RC filter is there for a completely different reason: to make the LPF behave.
Active LP filters turn into HP filters at a certain frequency. The RC output filter cures that to some extent. Sallen-Key filters are especially bad in this respect.
Check the TI application note sloa049d.pdf for a full explanation (p.14).
« Last Edit: August 12, 2024, 12:04:23 pm by Benta »
The following users thanked this post: Overspeed
Offline Kleinstein
« Reply #2 on: August 12, 2024, 06:57:05 pm »
With good op-amps, just the natural resistor noise can get significant. For lowest noise one may have to use a rel. small resistor and larger capacitor.
Online TimFox
« Reply #3 on: August 12, 2024, 08:18:51 pm »
To understand this question quantitatively, one needs to include the source impedance driving the filter circuit.
« Reply #4 on: Yesterday at 06:25:56 pm »
Hello
That for resistivity material measurement a voltage from a 4 wires resistance setup so resistance is low to very low and I think can be considered as pure resistive
The Op Amp is AD8421 or AD8458 I have also a dual OPA 189 circuit
Regards
OS
« Last Edit: Today at 04:30:18 pm by Overspeed »
