Just a play in SPICE for now. I am using a model for the BF862 that seems to gel well with reality (IDSS at around 14mA which is typical of tested parts, ~800pV noise @ 1kHz with the 1/f corner at ~1kHz.
12 in parallel return theoretically 800pV / sqrt12 = 231pV@1kHz. For the other active components I just used parts available in the LTspice library. LT1022 is a noisy op-amp, there still could be a small benefit from a quieter device in position U3.
Q1 through Q3 is a current source load for the common source, parallel- JFET input stage. U3 is the feedback amplifier, gain is set at 60dB (1000 Av). The other LT1022 is a servo that stabilizes the operating point of the JFET common source stage - to 3VDC at the common drain.
Circuit:
![](https://www.eevblog.com/forum/projects/low-noise-amplifier/?action=dlattach;attach=272428;image)
Closed loop gain:
![](https://www.eevblog.com/forum/projects/low-noise-amplifier/?action=dlattach;attach=272430;image)
Noise performance, input-referred (noise at output divided by the 60dB closed loop gain):
![](https://www.eevblog.com/forum/projects/low-noise-amplifier/?action=dlattach;attach=272432;image)
Feedback amplifier loop gain and phase (70 degrees phase margin at 1MHz bandwidth):
![](https://www.eevblog.com/forum/projects/low-noise-amplifier/?action=dlattach;attach=272434;image)
Servo amplifier loop gain and phase (approx 60 degrees phase margin):
