Does the first cascode, or current mirror, contribute significant noise anyway?
You would have to ask Toshiba if it's significant, I don't have the numbers for these transistors.
Actually, Toshiba gives certain numbers.
At 10Hz, HN4A51J datasheet shows 12dB noise figure at 6mA for circa 1800Ω source impedance.
Johnson is 5.4nV/rtHz and 12dB more is 21.6nV.
Subtracting Johnson, 21nV/rtHz is left. Voltage noise of the transistor is negligible, sub-1nV.
Dividing 21nV by 1800Ω (ignoring base spreading resistance) gives ~11pA/rtHz.
Repeating the calculation for 1kHz yields 2.2pA/rtHz, and this is consistent with expected shot noise of 15μA base current.
So 10Hz is well below the 1/f corner, and 0.01Hz is likely to be almost 32x more: 0.35nA/rtHz.
For the NPN we get 3000Ω, 9pA/rtHz at 10Hz and estimated 0.3nA/rtHz at 0.01Hz.
Total noise from both pairs is 0.65nA/rtHz. Dividing by 80mS transconductance of the diff pair gives 8.1nV/rtHz equivalent input noise voltage.
This is more than contribution of the JFETs at 0.01Hz (per the datasheet and SPICE model).
It's a pessimistic estimate, assuming exactly 1/f distribution below 10Hz. Perhaps real world is slightly better, but maybe not much better.
Or did I screw up the calculations?
I believe I originally got this procedure from The Art of Electronics, and it sounds sensible. I mean, the part about converting NF plots to in and en; the extrapolation to 0.01Hz is a separate matter.
I believe the current noises are uncorrelated. I modeled the current noise of one of the cascode transistors as a current source in LTSpice. With an amplitude of 0.3nA for AC analysis, V(out)/501 * sqrt(2) gave 5.8nV, which would of course equate to 5.8 nV/rtHz RTI. That indeed would be significant and would be comparable to the JFETs at that frequency. That current noise, incidentally, is converted to voltage noise with an effective transimpedance gain of 1733 Ohms at the base of the cascode transistors, which I have brought out of the shield with a test point. The voltage gain of noise at the noninverting input at that node is approximately unity. I may try to see how much this matters by probing that point, but I will need to build a second LNA to do so effectively.
With regards to sources of excess noise over the simulation, when I initially assembled the board, I did not wrap foil tape around the capacitors, and the drain of an MMBF4117 was connected to the input node, with its gate reversed biased to the negative rail (-4V3). Under these conditions, the noise at 0.01 Hz was in the neighborhood of 20-25 nV/rtHz, My recollection is that removing the 4117s and putting copper foil on the input and first HP filter capacitor had approximately equal impacts on LF noise [Edit: looking over previous data, most of this was from the MMBF4117s, and the foil was for stability - the cap after the first stage appeared to radiate to the 2x12uF AC coupling caps, causing positive feedback]. Moreover, the input JFETs are absolutely not biased close to their zero tempco point, which would require a tail current of about 14 mA * 16 JFET pairs. I haven't done a temperature sweep to see what the input Vos temp co is, but for a first pass calculation, let's say the datasheet figure holds for the drain currents in this design and that the tempcos are symmetrically distributed around zero. This would mean the Vos temco is around 425 nV/K, though it is likely worse, because both of those assumptions are likely false and would tend to underestimate it. The 0.01-1 Hz RMS noise (i.e., that more in frequency ranges where thermal fluctuations happen) is 2.2 nVRMS. As such, temperature fluctuations around 5mK (RMS) over 0.01-1 Hz would likely be sufficient to explain all the noise, assuming the estimated Vos TC is close, not just that which is in excess of the simulation. This is not too difficult to achieve, but such thermal variations only need to account for part of the measured noise, and the TC is probably worse than my back-of-the-envelope calculation. There are also, of course, parasitic thermocouples, which are a bit difficult to quantify but are still undoubtedly important. I have generally taken long captures in a steel box. This isn't critical for short measurements, but it helps avoid things that lead to "noise" such as touching the case while wearing socks, wearing socks in the vicinity of the amplifier, opening the door too quickly, etc. I believe this sensitivity is mostly a consequence of the big PP caps acting as antennas.
I have attached a preliminary VSD plot from the previous version of the amplifier. In this case, the 1/f corner is around 1 Hz. The non-inverting input of the first stage is shorted to ground here rather than through capacitors to isolate the effect of the input amplifier. The input stages are the same for the two versions, with two minor exceptions that I know to be inconsequential. The load resistors are 33k in this rather than 10k, and there is no resistor at the source of the PMOS that biases the folded cascode. Layout of the input stages is identical other than the routing of the traces for the input gates of the first stage. The main change was incorporation of the PP capacitors. Previously, I used paralleled 470nF C0G capacitors in place of all of these. In retrospect, the choice of the C0Gs for the HP filters other than the AC coupling one was probably a good choice. The bottom of the input stage is also shielded in this design. Both use BMI-S-230 shields, which have a solid cap rather than a perforated one. With the large AC coupling caps, I no longer had sufficient clearance for the bottom shield without redesigning the BMS board, so I had to remove it, and I had to switch to somewhat smaller shields that only have perforated covers. Also, as I have previously mentioned, the JFETs in this one were new and the ones in the current version had been salvaged. In any event I have not figured out the reason why this is so much better than the current version, but it is also notably better than the simulation. In all likelihood, the BJTs used in this design were adjacent on the reel to those used in the previous one. I'll get a longer capture of the noise floor for this design and add it to this response tomorrow.
Edit: As mentioned in a later post, I not longer believe the NSD shown in this post to be valid, so please disregard it.
