Short version and question:
Long story short: I think my CCFL backlight is worn, is that a reasonable assumption after ~10,000 hours of usage?
Will LED-backlight do better?
Long version:
Yesterday I replaced my trusty old Samsung Syncmaster 226cw monitor that I've been using daily for over 7 years now. Not because it was broken, but because after looking at a cheapo newish Philips monitor at my parents' I was under the impression that mine was rather dull in the brightness department while spec-wise it should beat the Philips.
Back home I went to up the brightness and contrast, only to find both were already set to the max! Hmm...
Googling backlight on this model turned up lots of issues with the 226bw needing new electrolytic caps on the power/inverter board. Now that board is also in my 226cw and goes under the type IP-43130A and causes a rash of hits when you google it (mostly people selling replacements).
But as you can see from the photo of the unit in my monitor, the caps look just fine. No bulging. Some pictures on the net show this power board with failed CrapXons, but these Samwhas are probably a bit better quality. I tested them with an LCR meter with ESR capability, and they measure beautifully.
Calling up the service menu (set brightness and contrast to 0, then hold the enter button > 5 seconds) shows that the usage is nearing 10,000 hours and 30,000 cycles.
All this combined led me to believe that it is actually the CCFL ageing rather than any other defect. Hence my question if this is a plausible assumption. What would normally be the expected lifespan of a CCFL backlight? And would LED backlight live longer?
