Hello, Paulie
Looking for discussions regarding voltage references (for DMM, for Power supplies, etc), I stumbled in this old thread and found your series of posts quite interesting, but had some difficulties to follow your experimental findings or to fully get your test method and steps you chose to do (but for the discussions held here this would be secondary, compared to your findings).
From what I understood:
(1) You measured several lower cost Voltage References, and of different types in an oven, after a given warmup time, using a kind of multiplexed ADC - as you pictured in that post
By "low cost" I mean pennies not dollars. "Voltage reference" refers to any device that might function as a transfer standard for calibrating 5 or 6 digit voltmeters or serve as reference for DIY meter or PSU with similar resolution.
(2) For several pictured devices, grouped as:
(a) IC references
Low cost bandgap devices. Most 20 cents or less each, 2 cents for the TL431.
(b) Zener+Diode assemblies
Back to back penny zeners. Less favorable voltages than the 2.5v bandgaps but potentially more stable. …
(c) LED and Transistor samples
LEDs and bipolar transistors. Not as promising but certainly inexpensive.
For them, you typically used that “fixed current” through a given voltage:(as ~5V) and a known resistor to measure their “output” voltage.
(3) There are data handwritten about the voltages you found, but
(4) I could not identify the influence of Temperature (like Temp. coeff.) you might have identified and measured.
(5) I also didn’t find if you measured/rechecked them for mid/long term stability at a given test condition (~ current & temperature).
After such long time, you may have tabulated these findings, or somehow summarized them on an attachment, but I couldn’t find. So, if you have done so, could please point them where I could study your findings?
Thank you,
Euthymios
P.S.
I’m an Mech.Engineer professionally and passionate about Electronics for more than 40 years, studying topics as a “serious hobbyist”.
Sorry for the “
inadequate indented” format, as this is an initial post (and done on an iPad, no mouse here); I had difficulties to do a nicer formatting and compromise this post.
