I bought myself a Wifi endoscope camera. The main module is a Wi-Fi accesspoint and with an App, the images can be received on your phone. I was satisfied this device was working well until I changed the default wifi password. Yes I lost it, I can not remember it anymore. I tried to reset the device so I could use the default 12345678 password...but no way
I asked the the supplier, searched the internet, tried the reset button in all possible combination with the powerbutton, I tried make a USB connect with Putty, I removed the wifi and memory module from the power pcb .. no success.
I guess the Wi-Fi configuration and password stored in the program memory of the Ralink RT5350.
So the big question, how do I reset the device?
Therefore, I decided to investigate the device further.
Wifi Endoscoop Module: ZCF99
Os: Linux 2.6.32
Port: 23 tcp open telnet BusyBox telnetd
WiFi module: Ralink RT5350
Memory module: Etrontech EM63A165TS-6G 16M X 16 Bit Synchronous DRAM (SDRAM)
Serial interface: Macronix MX25L3206E
Attached pictures show the various components.
Kind Regards
