Searched again today, and couldn't find much, not even the pinout, let alone how/what to talk with the battery pack over SMBus (side note, SMBus is like I2C, so most I2C chips would be compatible with SMBus
https://www.analog.com/en/resources/design-notes/guide-to-comparing-ic-bus-to-the-smbus.html ).
However, I did found some clues:
1. - all wires but one seem to be floating
2. - the wire that is not floating has a 0.1V level on it, so it is most probably a DO in zero logic
3. - for all other BMS chips except MAX17817, the commercial software needs only a USB to SMBus adapter in order to talk with the battery pack. For MAX17817, however, the same program needs yet another Arduino, so all 3 devices has to be in parallel on the same SMBus: the USB to SMBus adapter, the Arduino board, the battery pack. By the .ino file for Arduino, it seems that the only thing it does is send a stop to the SMBus (which will also release the SMBus for further communications).
4. - From the Arduino sketch, the slave address for MAX17817 seems to be 11 (in decimal).
5. - The paid software can work with a lot of BMS models, but it cost about $300, plus it doesn't start without a physical USB to SMBus bridge installed (made with SiLabs CP2112, which I don't have). No way to spend that much money for a random battery found in an EE dumpster bin. However, it gives some clues for what it is expected to be inside the flash memory of a MAX17817:
https://youtu.be/q-bojZF-EIoI have plenty of microcontrollers that can talk I2C. Raspberry Pi also has I2C pins, and in Linux there is quite a range of ready made generic I2C software tools, I2C libraries for C and Python, etc.
Point 3, and the fact that one wire is stuck in zero logic (point 2) make sense together. I guess that wire is the data line (SDA) of the SMBus, locked in 0 by the slave, probably because that's how the last end transmission has ended
https://www.arduino.cc/reference/en/language/functions/communication/wire/endtransmission/With all these hints so far, it feels like I'm halfway there (talking to the battery pack).
Any other advice, ideas, or things I should know before starting?
