Is there any good documents relating to a good method of securing a wiring harness or cable into a chassis? For different setups, lengths, gauges, wire insulation types, all that stuff.
I have read some military wiring requirements before but the documentation was very long dry and had no pictures or anything (interesting to note though the neat trick to cut a diagnol line into a grommet if you intend to use it in a key way to make the wire travel longer and less likely to remove itself from the grommet).
Like good manufacturing data with maybe some test results etc.
When I look at old equipment its secured like crazy with wires ties and stuff but I want to know the difference between good and bomb proof. I have an idea of what bad is, but I don't know how to properly design this without what is in my mind severe overkill.
