Author Topic: AMLA150 Loop Antenna help identify  (Read 328 times)
Offline daniel444Topic starter
« on: October 01, 2024, 05:37:53 am »
i bought this AMLA150 Active Magnetic Loop Antenna kit
i need help to identify the ic chip it uses as they have sanded the label off
i want to buy a replacement chip
the bottom of the chip has 592 written on it
it might use the same  chip as the  MLA-30 antenna
thanks
Daniel
Offline Bryn
    • mindsConnected
Re: AMLA150 Loop Antenna help identify
« Reply #1 on: October 01, 2024, 08:00:29 am »
Most likely to be an Si5351A.
mindsConnected
Alternate tech forum for all... we welcome engineers also!
Interesting long read: Create your own personal analog TV station
Online ftg
    • ftg's RF hax paeg
« Reply #2 on: October 01, 2024, 10:26:39 am »
That sure sounds like NE592.
The pinout also seems to match.
Here's a datasheet https://www.onsemi.com/pdf/datasheet/ne592-d.pdf
What on earth would a synthesizer do in a receiving antenna amplifier board?
The following users thanked this post: daniel444
« Reply #3 on: October 01, 2024, 12:21:38 pm »
thanks mate, im not sure why they sanded the label off the chip , but it has annoyed me
Online moffy
« Reply #4 on: October 01, 2024, 01:22:07 pm »
An equivalent to the NE592 is the National Semi LM733 if available.
Offline mikerj
« Reply #5 on: October 01, 2024, 02:09:56 pm »
Pretty much all of these cheap loop antenna kits use the NE592 or equivalent.
Offline Bryn
    • mindsConnected
« Reply #6 on: October 01, 2024, 03:31:49 pm »
Sorry... my research has failed me :(
mindsConnected
