I had all of those ideas, however I wasn't sure how well it would work to parallel PFC front ends from something like server PSUs, and reverse engineering a PC power supply sounds like a royal pain in the butt, they're very densely constructed and poorly documented. As far as taking feedback from the output, that might work however I already have the completed and working inverter board and I have put it through its paces and verified that it does exactly what I want it to do when fed 400VDC, so why mess with that? I believe the inverter controller IC does some regulation on its own however it still needs a reasonably constant input voltage.
Also the idea of designing something myself intrigues me as I have never really messed with active PFC, but I'm not sure what sort of challenges I'm likely to face. This will likely be a one-off constructed by hand, not something I'm going to produce.
Generally speaking even the cheap chinese EGS002 sine wave inverter module which costs 3USD has feedback.
All you need is a bump in duty cycle when the input voltage goes lower.
240Vac has a peak of 340V so the inverter should be running fine for voltages quite a lot lower than 400V DC.
And it may be easier to create a different kind of circuit than APFC to get a nice constant 400V DC.
Voltage doubler from 120V mains should create 340V so we are missing 60V at minimum (under load the voltage will drop down to most likely 300V or so, depending on capacity).
Without PFC functionality this is a fairly easy task as we only need a boost topology or any other type of switching power supply.
Using isolated type (like half-bridge) the circuit only has to handle the 60-100V times whatever current the inverter needs.
1.5kW from 400V gives 3.75A so the circuit only needs to handle 400W at top. That's a far easier task.
And it can be done using easily available parts like pretty much any ATX computer power supply which already has everything you may need to build one.
Or just have a go at 494 or whatever may be your choice.
If the load is slow to change then even mains operated circuit is an option.
A small transformer to boost 120V mains to around 160V (primary to mains, secondary in series with mains, again, transformer only carries the excess power).
Then you only need an SCR rectifier stage.
With an MCU it should be very easy to control as we don't need quick feedback.
Neither of those ideas will be "nice" on mains as neither has PFC.
As for chips.
I have a schematic of a 600W APFC circuit on the table.
Uses NCP1654 along with STW20NK50Z power mosfet.
Also, one thing like to suggest.
Why not use a split inductor (autotransformer) in the APFC stage ?
Lowers the peak voltage at the switching transistor so it can be cheaper and have lower RDSon.
I have read articles about those, mainly for high voltage differences (170V peak 120V mains to 400V I think is quite a lot) in boost topologies.
