Author Topic: Unknown SOT-23 devices, lost cause?  (Read 1539 times)
Offline PeterFWTopic starter
    • Stuff that goes boom
« on: March 18, 2015, 01:21:37 am »
Hello!
Most likely this is futile but i will try, google dit not help me, i got a couple of SOT-23 parts:
The only things to measure i have are a multimeter and a DSO,
my meter says:
GHMH9: 2 <> 3 shorted
H9LF4: 2 <> 3 shorted
S7W5: 2 <> 3 shorted and anode on pin 1, kathode pin 2 with 0,51V UF
The others do not show annything, before i try to determine by try and error what they might be, i thought i ask here.
Annyone seen one of these before, i can not remember what they are.
They were in an order from a local supplyer, years ago.
They must be different types of FETs, two of em may be JFETs.
Greetings,
Peter
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Unknown SOT-23 devices, lost cause?
« Reply #1 on: March 18, 2015, 03:47:13 am »
E4L = BAT54 http://www.s-manuals.com/pdf/datasheet/b/a/bat54_utc.pdf
S7W = maybe BF511?  Something by Rohm?  Not sure.
SA = but, that doesn't look like an "A"... not sure what that is.
Can't find anything on the HMHS or H9LF4.
I probably shouldn't transcribe these numbers because now this thread will be the only thing that ever shows up in searches for those parts.  http://xkcd.com/979/
Seven Transistor Labs, LLC
Offline Macbeth
« Reply #2 on: March 18, 2015, 03:50:19 am »
SA could be BSS123 MOSFET
