Hello all,
I'm using a LG iG5 Variable Frequency Driver to control a blower. Now I want to control it using RS485, I've already connected it and I'm able to write to the register using modbus RTU.
nevertheless I have an issue, in the manual I've found that I must configure DRV-03 (dru) and DRV-04 (FR9) to be 3 and 5 respectively so that I can use modbus-RTU.
" alt="" class="bbc_img" />
with both options set to modbus-RTU I'm able to set the motor speed writing to register 5, but I'm unable to start and stop the motor writing to register 6.
If I set only DRV-03 to 3 I'm able to start and stop the motor but I can't change the speed.
Do you have any idea of what can be wrong? how can I control motor speed and state simultaneously?
looking forward your reply,
Best regards, Mauro.
