Author Topic: The search for a (CHEAP) supercomputer...  (Read 18354 times)
Offline GeorgeOfTheJungle
  • Country: tr
Re: The search for a (CHEAP) supercomputer...
« Reply #50 on: May 02, 2017, 12:10:49 pm »
None of those programs have been ported to ARM, and the companies involved have basically no incentive to do so.
Ported to ARM? What does that mean? Most things these days are written in C or higher level languages, it should be a matter of hitting "compile" in the proper toolchain (yeah, I know, I know...).
Offline brucehoult
« Reply #51 on: May 02, 2017, 12:26:05 pm »
Cool, now the OPi (with dom0's code above) gives:
pi@orangepi:~$ gcc -lpthread -O0 threads.c -o threads
pi@orangepi:~$ time ./threads
real   0m0.831s
user   0m2.070s
sys   0m0.230s
But OSX does not have random_r, any ideas?
On an Odroid XU4 (quad Cortex A15 @2.0 GHz) I got:
real   0m0.398s
user   0m0.710s
sys   0m0.300s
Offline CJay
« Reply #52 on: May 02, 2017, 12:26:19 pm »
Would be interesting to see how a current Intel chip stacks up against something like an ARM, core to core so to speak if the compiler/hardware could be persuaded to run code on just the CPU core and not the 'extra' (potentially) performance enhancing on chip peripherals.
An almost but not quite comparable example, ISTR the 1940s Bletchley Bombes were capable of outpacing a generic desktop PC CPU until a few years ago, obviously that was a highly specialised application and one that the Bombes had been specifically designed and optimised for but even so, 60 or so years of technological development hadn't produced a generic machine that was any faster
Offline brucehoult
« Reply #53 on: May 02, 2017, 12:34:33 pm »
Ok so I simply won't fill the 16MB buffers with random(), just average whatever happens to be there (most likely zeros or garbage) as doubles in parallel in 4 threads:
https://gist.github.com/xk/b8b2ff4ab1455237906a8b13e3f1f02f
The i7 Mac:
unibodySierra:Desktop admin$ gcc -O0 threads.c -o threads
unibodySierra:Desktop admin$ time ./threads
real   0m0.054s
user   0m0.084s
sys   0m0.073s
And the OPi Zero:
real   0m0.166s
user   0m0.440s
sys   0m0.140s
And the Mac now is 0,166/0,054= 3x times faster, and more than 100x as expensive.
And for this, Odroid XU4 is:
real   0m0.212s
user   0m0.130s
sys   0m0.625s
And Odroid c2 (quad A53 @1.5 GHz):
real   0m0.142s
user   0m0.350s
sys   0m0.140s
This benchmark is really too short to measure accurately on any of these systems, but especially Intel.
Both the Odroids have less User time than the Orange Pi, the XU4 by a factor of 3.4x. They are both Raspberry Pi-sized SBCs. The C2 costs $5 more than a Pi. The XU4 is about twice the C2, but a 4A power supply is included. Both have 2 GB RAM, gig ethernet, and much faster SD card and USB than a Pi (and eMMC too).
  • Country: tr
« Reply #54 on: May 02, 2017, 12:50:30 pm »
Bruce I have to admit that I swithed the OPi to the performance governor for the tests:
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
interactive
echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
performance
Because if you don't do that it takes a while for the cpu to speed up...
« Last Edit: May 03, 2017, 06:18:03 am by GeorgeOfTheJungle »
  • Country: tr
« Reply #55 on: May 02, 2017, 02:33:43 pm »
But the xu4 has 8 real cores, so let's try that versus the i7 4 cores + hyperthreading shall we?
8 threads and 96MB buffers : https://gist.github.com/xk/ba76a426e4c391c0b22b3eddbdb11898
The xu4 8 ARM cores big/little:
pi@xu4:~$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
performance
pi@xu4:~$ gcc -lpthread -O0 threads.c -o threads
pi@xu4:~$ time ./threads
real   0m2.502s
user   0m6.875s
sys   0m9.675s
The Intel i7 4 cores+hyperthreading:
MBP-17:Desktop admin$ gcc -O0 threads.c -o threads
MBP-17:Desktop admin$ time ./threads
real   0m0.383s
user   0m0.904s
sys   0m0.874s
« Last Edit: May 02, 2017, 03:03:18 pm by GeorgeOfTheJungle »
Offline brucehoult
« Reply #56 on: May 02, 2017, 04:05:20 pm »
Not really. The big and LITTLE cores don't ever run at the same time as each other. For performance questions you should ignore the LITTLE cores.
  • Country: tr
« Reply #57 on: May 02, 2017, 04:12:07 pm »
I see the 8 cores @ 100% there in htop:
pi@xu4:~$ cat loop.sh
while [ true ]; do
    ./threads
done
pi@xu4:~$ sh loop.sh
« Last Edit: May 02, 2017, 08:11:49 pm by GeorgeOfTheJungle »
