Ok well this is a bit off the main topic but I did not want to start a new thread. Basically I have been working on a solder station, for 24v Hakko Irons. I've been basically just using scrapped parts to keep the cost to almost free. The iron handles are 24v 50W so I found two transformers one labeled 60W 24v and the other is about the same size and also 24W.
Now I wanted to test the load on these transformers and find out how well, and cool they handle at 50watts of output. This is why I started using the lm317s I had laying around as a dummy load.
I took two lm317s, and threw wired them both up with 5watt 1.2ohm resistors as current syncs. This way each one would draw one amp. I kind of want to build daves dummy current load for a fine 0 to 1 amp load, and then use a bunch of lm317s to add one amp at a time to the fine adjustment. Well here is the problem with 1 lm317 connected I would draw the expected 1 amp of current, then I hooked up an identical LM317 to the output of the transformer in parallel, but I did not get two amps!! I ended up drawing 3 to 4 amps of current. What is going on here?? Two one amp loads in parallel should draw 2 amps from the voltage supply not 4??!! Wondering if it was a heat issue I stuck the whole device in the freezer for 30 mins then turned it on, still drew 3 to 4 amps! Even more strange when I swapped transformers the circuit drew 4 to 4.5 amps!!!!
