I'm making a (hopefully) standalone production test fixture for a product with bluetooth. The DUT has a 16MHz crystal, and from what I understand that needs to be +/-50ppm max for BLE to work. I can output the clock on a GPIO for measurement and the DUT micro has trim capabilities built in, but I need to accurately measure the clock and get that data to the fixture processor to set the trim.
Because I plan on making many of these fixtures, I would rather not have a boat anchor frequency counter hooked up to each one. Cost is also always an issue for many fixtures. Something self contained that doesn't itself require calibration would be optimal.
What are the best options for measuring a 16MHz clock accurately enough (+/-5ppm?) to perform this trim in a formfactor that is ideally board mounted, self contained, and inexpensive?
