Author Topic: Linear power supples in burglar alarms  (Read 1597 times)
Online 5U4GBTopic starter
« on: January 17, 2025, 06:37:00 am »
Not quite sure which category this would go under so I'll post it here: Why do so many burglar alarms have linear power supplies?  I was replacing the crummy alarm this place has with an ESP32-based one and swapped out the linear power supply with a Meanwell SMPS, assuming the power supply just went with the crappiness of the rest of the alarm.  Then I looked for photos of alarms online and most of them seemed to feature honkin' big transformers feeding AC into some sort of linear supply circuit.
Why don't they use SMPS modules?  I assumed this one was a leftover design from the 1980s (did I mention it's a crappy alarm?), but given how many others do it maybe there's some other reason.
And for anyone else doing this, the first time I tried to power it up with a load connected it didn't actually power up.  After quite a bit of head scratching it turns out there was an M205 fuse hidden inside a side panel in the screw terminal block where the mains came into the cabinet which was fine for the linear but not quite high enough capacity for the SMPS.
And as an aside, what fuse should I replace it with?  Meanwell recommend one "rated slightly higher than [the PSU input current] value", with their example being a 4A fuse for a PSU with a 2.2A max current draw at 115V.  In this case it's 0.42A at 230V, so a T1AL250V?
« Last Edit: January 17, 2025, 09:54:36 am by 5U4GB »
Offline hli
Re: Linear power supples in burglar alarms
« Reply #1 on: January 17, 2025, 08:27:51 am »
(Somewhat) uneducated guess: it reduces the number of things which can break. SMPS need circuitry on the mains side, which is susceptible to break more easily / often than stuff on the low-voltage side. So using a linear supply makes it easier to get higher reliability. Probably a SMPS can more easily be interfered with by disturbing mains / injecting voltage pulses, so it also might be a security thing.
Offline fourtytwo42
  • Interested in all things green/ECO NOT political
« Reply #2 on: January 17, 2025, 10:28:07 am »
Possibly cost but also EMC issues particularly with all those long  cables.
Online RoGeorge
« Reply #3 on: January 17, 2025, 11:10:18 am »
Linear supplies are more reliable, harder to tamper/influence from outside, probably cheaper, too.
Saying this because linear power supplies do not need low ESR capacitors, do not produce high temperature, do not dry their electrolytic caps, do not produce EMI, do not waste a few W in idle, they are not influenced by nearby magnets or by nearby EMP tampering.
All these look like possible advantages of the linear over SMPS, but I don't really know if any of these is considered, or a requirement when designing alarms.
The following users thanked this post: Someone, johansen
Online inse
« Reply #4 on: January 17, 2025, 11:20:38 am »
… linear power supplies do not produce high temperature, do not dry their electrolytic caps, do not waste a few W in idle…
While I agree to the other statements, those are definitely not true
Offline wasedadoc
« Reply #5 on: January 17, 2025, 11:22:21 am »
Mostly correct but certainly not about idle power. Linears waste more than switchers.
Offline Zero999
  • 0999
« Reply #6 on: January 17, 2025, 11:55:11 am »
… linear power supplies produce high temperatures, dry their electrolytic caps, waste a few W in idle…
Fixed.
The following users thanked this post: inse, Siwastaja, 5U4GB
Online Siwastaja
« Reply #7 on: January 17, 2025, 01:22:12 pm »
This must be a joke, right?
Online tszaboo
« Reply #8 on: January 17, 2025, 02:01:16 pm »
I was working at a security systems company a long time ago. We said we had to build in some "gravity" into the system. It needed thick steel cabinet, large relays, a linear power supply with a transformer, and a lead acid battery backup. Customers (mis)identified weight as quality, so a heavier system was perceived as higher quality. Efficiency was zero concern, as it wouldn't result sales.
In a way an oversized, but then this is supposed to work for years, so that's not an inherently bad thing.
Online RoGeorge
« Reply #9 on: January 17, 2025, 05:30:42 pm »
Fixed.
No, that's forgery with quotes.  Straight to jail!  :)
I never said what you quoted as my words there.
I believe linear is better than SMPS because I expect a burglar alarm to need very little DC current, probably not more than a few mA.  At very low currents, a linear PSU has all the advantages I've enumerated already in reply #3.
Offline Zero999
  • 0999
« Reply #10 on: January 17, 2025, 08:33:13 pm »
Fixed.
No forgery. I simply corrected the part of your post I quoted. That's what I meant by adding the word fixed, under it.
You're mistaken. Linear power supplies aren't better for low currents. Small transformers have large core losses, which are present, even when no power is being drawn. The standby power consumption of a linear power supply can be 5W or more. Modern switched more power supplies draw less than 0.5W in standby in order to comply with the most recent EU directive.
« Last Edit: January 19, 2025, 10:56:35 am by Zero999 »
« Reply #11 on: January 18, 2025, 10:51:43 am »
Been there :-).  I once worked for a company where some of the guys got tasked with opening up some devices they were shipping and hot-gluing in wheel balance weights to add, uh, quality to the device.
Offline Poroit
« Reply #12 on: January 19, 2025, 03:06:29 am »
[/quote]
That sucks....can you tell us the product type?
Offline ohren
« Reply #13 on: January 19, 2025, 04:23:54 am »
Wheels, amirite?
The following users thanked this post: 5U4GB
« Reply #14 on: January 19, 2025, 08:27:31 am »
Oh, it wasn't a poor-quality product, it was just that the electronics in newer generations had been integrated and miniaturised to a point where it felt like half the device was missing, so they re-added the mass of the missing part.  Imagine some industrial sensor where 30 years ago the case would have been full of discrete circuitry while now it's mostly full of fresh air.
Offline Njk
  • Country: ru
« Reply #15 on: January 19, 2025, 11:45:28 pm »
Old time ago, when a HI-Fi equipment was in short supply, my friend bought a couple of big speakers in a used equipment store. Later he found that in one of the cabinet the standard loudspeaker is substituted with a very cheap one. To compensate for weight difference, a big smoothing iron is fastened inside the cabinet.
As for the PSU types, I think there may be some EMC concern. My car alarm system uses 433 MHz RF channel to communicate with the indoor unit. So I prefer to power it from old linear PSU, just to be sure.
