The LED is a nice Cree CXA3050 series one, about $30 equivalent each, i got two of them more or less randomly, of different colour temperature.
I wanted to see what modern high-power LEDs look like, how hard is it to keep them cool, how to drive them, etc - get familiar with the technology.
If it was to survive all that, and be viable, then it would end up as a light in a room (outshining everything already there
There aren't exactly ready-made drivers to fit it's specs around here, i'll have to order one online, and i hate doing that.
Therefore, i hook it up to a tweaked-down 45V power supply (which are found in abundance everywhere), with a simple current regulator.
The reason for simplicity is - there is pretty much nothing that can go wrong with that LM350 circuit, unless i screw it up (or rather not screw it tightly enough to the radiator).
My trust in things i make is proportional to their simplicity - a constant current buck converter is not that hard to make, but i would trust it much less than a simple, stupid linear one.
I've already verified that the cooling is sufficient with a huge safety margin, so no need for temperature monitoring.
So, that's all there is to it.
