Author Topic: Linear lab power supply  (Read 97368 times)
Offline xavier60
Re: Linear lab power supply
« Reply #375 on: May 05, 2019, 09:57:09 am »
The Omron relay configures the two 15VAC secondaries as parallel or series to suit the output voltage.
The changeover occurs at about 15V.   The changeover threshold can be set to another voltage by holding the power button pressed for a few seconds. The new changeover threshold becomes set to the same as the present output voltage.
A blue LED indicates when the secondaries are in series which reduces the current capability.
The blue LED warns by flashing  if the Current Control is set to higher than what the transformer can safely output.
More: The updated schematic mainly has a CV anti-windup idea which was suggested by Kleinstein. The compensation feedback for the CV op-amp is now taken from the diode OR-ing node.
Minor schematic update 31/05/19
« Last Edit: June 14, 2019, 11:35:46 pm by xavier60 »
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline JuanGgTopic starter
    • My personal blog
« Reply #376 on: May 13, 2019, 07:31:55 pm »
The Omron relay configures the two 15VAC secondaries as parallel or series to suit the output voltage setting.
The changeover occurs when the output is adjusted to over 15V. If needed, the changeover threshold can be set to another voltage by holding the power button pressed for a few seconds. The new changeover threshold becomes set to the same as the current output voltage.
More: The updated schematic mainly has a CV anti-windup idea which was suggested by Kleinstein. The compensation feedback for the CV op-amp is now taken from the diode ORing node.
Again, that is a really neat power supply!
All my power supply's files: schematics, PCBs, firmware, 3d printed parts, front panel overlay... are available here: https://github.com/Juan-Gg/Linear-lab-bench-power-supply/tree/master
And a short description over here: https://juangg-projects.blogspot.com/2019/05/linear-lab-power-supply.html
    Juan
Offline xavier60
« Reply #377 on: May 14, 2019, 02:38:16 am »
I can now confidently say that this topology can be made to work well.
« Last Edit: November 12, 2019, 12:02:00 pm by xavier60 »
Offline shoorup4eg
  • Country: by
« Reply #378 on: November 01, 2022, 08:20:33 am »
Hello
sorry for the necroposting.
I want to make a power supply with current and voltage regulation controlled by a microcontroller. I repeated the circuit in the simulator. This scheme does not work in the simulator. What am I doing wrong? The simulation file is attached (NI Multisim 14).
Offline xavier60
« Reply #379 on: November 01, 2022, 08:52:13 am »
Could you post just the schematic?
« Last Edit: November 01, 2022, 09:02:17 am by xavier60 »
Offline shoorup4eg
  • Country: by
« Reply #380 on: November 01, 2022, 09:18:40 am »
Yes of course
Offline xavier60
« Reply #381 on: November 01, 2022, 09:39:18 am »
I can't see anything wrong. Ill have a closer look when I get home. There is an updated schematic on another thread Ill link later.
« Last Edit: November 02, 2022, 09:28:12 am by xavier60 »
Offline shoorup4eg
  • Country: by
« Reply #382 on: November 01, 2022, 10:03:10 am »
I can't anything wrong. Ill have a closer look when I get home. There is an updated schematic on another thread Ill link later.
Ok. I'm waiting
Offline xavier60
« Reply #383 on: November 01, 2022, 12:22:21 pm »
Offline xavier60
« Reply #384 on: November 03, 2022, 05:08:27 am »
Yes of course
Just to be sure, the opamps  are upside down? I can't clearly see the pin numbers.
Offline shoorup4eg
  • Country: by
« Reply #385 on: November 04, 2022, 01:24:00 pm »
everything according to your scheme.
I can't achieve stable circuit operation in the simulator. I'm trying other designs now.
Offline uliano
« Reply #386 on: June 18, 2024, 09:16:35 am »
Q2 as a Common Base amplifier causes a possible complication.
Because it's non-inverting, the op-amp inputs had to be swapped.
When reference voltage  is connected to the inverting input and the feedback divider to the non-inverting input, the op-amp can't ever function as a true Miller Integrator. The minimum gain can never be less than unity.
For the voltage regulation loop, a small amount of proportional gain can and does improved stability.
For the current loop it is an uncertainty.
With Q2 as a Common Emitter amplifier again and a bit of tweaking, the response and stability are near as good as the Common Base version.
in this answer (#122) you introduce for the first time in the schematic the mysterious U1. My fault not having read all the messages in the thread, but I can't figure out what can it possibly be.
Offline xavier60
« Reply #387 on: June 18, 2024, 09:35:10 am »
The "U1" symbol is just the way DipTrace represents the power supply pins of the TLC072.
The following users thanked this post: uliano
Offline uliano
« Reply #388 on: June 18, 2024, 09:50:32 am »
 :phew:  I should have thought a little bit more over it and I could have gotten there
