Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Limit Push Button Digi Pot Output Resistance ( Maxim DS1809-10 )
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Limit Push Button Digi Pot Output Resistance ( Maxim DS1809-10 ) (Read 876 times)
interrupted
Newbie
Country:
on:
August 13, 2017, 12:58:12 pm »
like the Threadtopic already says, i am looking for a way to limit the Output Resistance Range from a Maxim DS1809 IC which supports up to 10k Output Resistance. The Application Notes dont say anything about this, by myself i was only able to archive it "somehow" with parallel hooked up fix Resistors. Which turned out as an absolut stupid idea which wont work.
Reducing the Output Range from 10 to 5k without adding a non linear behavior is something i am looking for. Maybe i should try 2 of the DS1809 Stacked to half the output.
But, i am pretty sure that its not needed to go that ugly way. Maybe anyone got a hint how to archive this?
Spec Sheet for the IC is
https://datasheets.maximintegrated.com/en/ds/DS1809.pdf
Thanks!
Juergen
Logged
danadak
Super Contributor
Country:
Reactor Operator SSN-583, Retired EE
Re: Limit Push Button Digi Pot Output Resistance ( Maxim DS1809-10 )
Reply #1 on:
August 15, 2017, 11:59:52 am »
What is the 1809 controlling, what is its variable R being used in rest
of solution ?
One possibility, convert the pot voltage to a current source with OpAmp.
Again depends on answer to above question.
Regards, Dana.
Last Edit: August 15, 2017, 12:02:06 pm by danadak
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
