It worked ! The device is running fine with 0.8A load on the +12V and -12V rails. Woohoo! No AC current left in the DC lines and I am almost certain there is absolutely no ripple on there ! Maybe it's time for a new scope eh!
Please change the colour of your negative output wire - violet is good - otherwise I shall not be able to sleep worrying that you will think it is positive and blow something up!
