Hello, currently I am working on renovating an LED array project, specifically making the power adapter smaller. Currently, we use a 36V .69A AC/DC wall adapter that's fairly big, around 74x43x40mm with a size m dc power jack (similar to a tri-mag icm24). Inside of the driver, a buck converter reduces the 36V to 24V for the array. In order to make this smaller, I was considering switching to a smaller USB-C power adapter to give the same wattage, then using a boost converter and current limiter, with a pd trigger inside of the cable to get the same result. A question I have for people much smarter than me is if this would be a feasible and smart power connection for a lamp (considering the new aspect of human error this would introduce), if the boost converter would dissipate a large amount of power as heat within the driver, and if there was a smarter solution to this to decrease the overall size of the power adapter without switching to USB-c. Thanks!
