Author Topic: Arduino board in size DIP26 (33 x 10mm)  (Read 17715 times)
Offline avandalenTopic starter
« on: February 12, 2024, 11:42:48 am »
I have developed a revolutionary tiny Arduino board: the Arduino DIP. It is an Arduino compatible board that is smaller than the ATmega328P-PU chip on the Arduino Uno itself.  :-DD
It has the same features as the Arduino Uno or Nano.
See for the circuit at my website: https://avdweb.nl/arduino/attiny3217/dily3217
Help wanted: Who has any ideas for improvement? Then I can include that in the design before making the PCB.
Who has  a better name for the board?
Here is the circuit:
« Last Edit: February 14, 2024, 01:27:01 pm by avandalen »
Offline coromonadalix
Re: Arduino board in size DIP26 (33 x 10mm)
« Reply #1 on: February 12, 2024, 04:15:36 pm »
not bashing your product / design
you have the Adafruit ItsyBitsy M0    28 pins dip,  you win by 2,  but more powerful   ???
« Reply #2 on: February 12, 2024, 06:26:16 pm »
Yes, I know, there are many Arduino boards which are more powerful. But not in this small size. The ATtiny3217 (and the STM32) is one of the best choices when PCB space is limited and a more powerful chip is not needed.
« Last Edit: February 14, 2024, 01:30:17 pm by avandalen »
Offline MarkT
« Reply #3 on: February 12, 2024, 09:27:26 pm »
Nice unit - but I have a slight quibble:
Technically its 0.1" wider and takes up a larger area - not really smaller but shorter...
If you had a version with castellated pads on the edge you could get down to 7.5mm narrow to be truly smaller and surface-mountable.
Offline Benta
« Reply #4 on: February 12, 2024, 10:09:33 pm »
How is it "revolutionary"?
« Reply #5 on: February 13, 2024, 01:20:13 am »
ok  you want US to help you in your commercial product is that it ?
mm not
Offline S. Petrukhin
  • Country: ru
« Reply #6 on: February 13, 2024, 06:14:37 am »
Have you studied works of V.I. Lenin: "Prerequisites of the revolution"?  :)
And sorry for my English.
Offline tooki
« Reply #7 on: February 13, 2024, 08:01:10 am »
What’s the key advantage over, say, one of the DFrobot Beetle series? They’re a smidgen bigger, but they include the USB port for programming.
https://www.dfrobot.com/product-1075.html
« Reply #8 on: February 13, 2024, 09:28:11 am »
I have also an USB port for programming on board. ;)
« Reply #9 on: February 13, 2024, 09:30:21 am »
You're right. I will try to make the board a little smaller. I can't use castellated pads because there are parts at the bottom side.
Online kripton2035
« Reply #10 on: February 13, 2024, 10:10:48 am »
and what about the seeed xiao ? it's really smaller...
Online DavidAlfa
« Reply #11 on: February 13, 2024, 12:55:52 pm »
Those atmega and atiny are ancient, why develop for them when there're so many M0/M0+ MCUs around?
Way more powerful, while also cheaper.
I would go with the STM32G030 ($0.35), or the py32f002A ($0.11), the py32 is crazy cheap and has Arduino support .
« Last Edit: February 13, 2024, 01:06:08 pm by DavidAlfa »
« Reply #12 on: February 13, 2024, 04:43:28 pm »
yeah  same here
and still like other members don't understand  the "revolutionary"  thing ??  sound more like outdated,  small footprint but not practical  mcu wise
« Last Edit: February 14, 2024, 01:57:35 pm by coromonadalix »
« Reply #13 on: February 14, 2024, 01:21:32 pm »
Yes, I know, the STM32 is more powerful and cheaper than the ATmega and ATiny. A nice little PCB too!
« Last Edit: February 14, 2024, 01:31:58 pm by avandalen »
Offline sparkydog
« Reply #14 on: February 14, 2024, 04:11:55 pm »
Having SDA and SCL on opposite sides seems... not ideal? Any thoughts on swapping 1(11) and 13(GND) so that they would be adjacent?
