If you know the proper plug is right, get that.
I just found the MCX, which I already had, worked okay- but its not the proper plug.
Its ugly, its very ugly, but its available and should last if you enclose the device and don't repeatedly remove/insert them.
Because MCX connectors are really delicate. Not quite as bad as u.fl connectors but close.
