Hello, I would like to use the MIC61300 LDO to generate 2.5V and 3.0V power rails from a 3.3V power supply. I expect current draw of 100 mA on the 2.5 V rail and about 250mA on the 3.0 V rail. Would the MIC61300 be an appropriate choice for my requirements or should I pick another LDO? Would the 3.0V rail be problem if considering the 350mV max dropout voltage spec and it would enter dropout region? Any help is appreciated.
