2N3055, thank you for the info, that is all very good to know. Your scope looks very nice too, such a pretty looking interface there!
Some mid-range DSO have an input for an external reference clock. If you have one of these, you can connect them to your GPSDO.
Dang, mine doesn't seem to have one. I have the 1104X-E but unlocked to be 200Mhz (as if I need that haha), and it seems I'm stuck with the internal reference. Based on what 2N3055 said though I shouldn't have any issue with that.
Also: since it seems you have a 4-channel DSO, I would suggest you measure on each channel:
1) 1PPS leading edge (trigger)
2) Leading edge of the output of the 74HC390 divider that is fed to the TIC
3) OCXO 10 MHz output.
4) And most importantly: the TIC output (that goes to the MCU ADC input)
This will really show you how Lars' GPSDO works.
Alright, I finally got it all set up! I had a medical procedure last week which glued me to the couch so I had to take a week off this project, but I am back now!
Also, I got my diodes (1N5711) and results seem to be basically the same, but at least I have the recommended piece now.
SO, I have my four probes hooked up the way you recommended. Here is the way they are arranged on the screen:
Blue: 10Mhz (obviously haha)
Yellow: 1pps from GPS (trigger)
Green: Pulse out from HV4046 Pin 15 (hooked up right after diode, before resistor so it was easier to see on the screen. Is that ok?)
Purple: 1Mhz out from HC390 pin 7
That was super helpful for me to see what was really happening! So my understanding now is that the 1pps from the GPS sets the HC4046 high on pin 14, then as soon as the 1Mhz hits pin 3 it drops it back down. That cycle determines the TIC pulse width of the pulse going to the ADC (A0) on the Pro Mini.
Here are a couple questions that I now have: 1. I THINK that the TIC pulse width stability indicates whether or not the 1PPS and 1Mhz are synced, and the Pro Mini is using that TIC pulse width CHANGE to determine the DAC value to send to the VCO to make them synchronized... so if the width stops varying then it means they are synced and if it keeps changing then the VCO voltage is slightly adjusted till it stops changing... is that correct?
2. Take a look at the falling edge of my green line (the TIC to the ADC). Does it fall off slowly like that because of the 1nf cap? If so, is that a reasonable looking falling edge there or should I try a different capacitor?
3. I asked this one before and you weren't sure, but I was hoping that now that I have the correct diode and better screenshots that you might have a better idea: My setup seems to stabilize well, and the TIC values get down to like <20ns for a couple cycles, then it locks, and immediately the "pre-filter" changes from 1 to 16 and everything goes haywire and it loses its lock. This keeps repeating. As soon as that lock is lost (couple seconds), the filter changes from 16 back to 1 and within a few seconds my TIC values are back to <40ns, and eventually back to <20ns. What is that 1 and 16 filter value and why does it change? It seems to be the reason I can't maintain a lock for more than 10 seconds. In the time it has taken me to type this post, the locked/unlocked cycle has repeated probably 10 times. What is that pre-filter? I read Lars' pdf but I don't fully understand some of the more advanced parts.
4. I attached some GPS signal screenshots. I have an active antenna hanging in my window on the blinds. Are these GPS signal strength strong enough? Sometimes I get only 2 or 3 above 30dB, but have a ton in the high 20's. Is that sufficient?
As always, thank you so much for your help. This is a really fun project. It is absolutely unnecessary for me to have this level of accuracy for the work I do (fixing vintage audio equipment) but it is such a fun side-project that I just can't stop! I want a super accurate reference just for the pleasure of having it lol.
P.S. That was so cool hooking up all four probes and actually getting the trigger setup to capture all four like this. I tried this in the past (only had a scope for a couple months now) and couldn't get it. I'm glad I gave it another shot here because I feel like my scope skills doubled just from this little "exercise" you gave me. So thank you for that.
P.P.S. I got a couple NEO-8M modules for a decent deal. I will swap for one of them once I get the 7M working and see if there is much difference.
