I have the results for my "24 hour" test run, comparing my RFS project's frequency stability against a modern day respin of the rather worthy James Miller GPSDO (essentially just a GPS rx module update using a u-blox M8T instead of the original Jupiter GPS engine).
The "24 hour" test run was more like a 26 to 28 hour run, hence the quotes. Anyhow, I didn't manage to achieve the half cycle in 24 hours target I'd hoped to hit but did manage to better the one cycle drift limit in 24 hours which I'd not been able to manage in any of my earlier tests over six months ago.
One of the issues being the question of the sensitivity of the LPRO-101 to barometric pressure variations which in my location, showed up as a drop from 1003 to 983 mBars during the past three days, over half of which occurred in just the last 24 hours. According to this Dec 1975 NIST document
https://tf.nist.gov/general/pdf/82.pdf I would have expected the RFS to have dropped in frequency rather than show the increase revealed by my test run.
That NIST document whilst getting on for half a century old offers some interesting insights into Rb lamp atomic clock technology which remains essentially unchanged between then and when my LPRO-101 had been manufactured circa 1998 with some 23 years worth of technological refinements (eg the unnamed unit they'd used was twice the volumetric size of the LPRO).
I'd started this test run yesterday, just before teatime (6pm BST or 1700 hrs UTC - the scope date/time being 4 minutes behind UTC makes this a relevant point), possibly even an hour earlier but it hadn't occurred to me to take a screenshot or two to mark the event. If I had, it would have looked a dead ringer for the final screenshot of the sequence I took over the final 5 hours or so of the run.
I've archived them into two 7z files to stay within the EEVBlog 5MB server limit and attached the first 7z file plus the first 9 images uncompressed to this post with the second 7z file plus the last 9 uncompressed images to the follow up post for anyone the least bit curious in my RFS v GPSDO stability contest. I've included the uncompressed images as a common courtesy to those, who like me, find it a bit of an imposition to have to actually download an attachment before you get the chance to view its contents.
I've chosen to trigger from the GPSDO (CH2) even though that's the source of the 6ns pk-pk wobble simply because long term it remains within a few ns of the World's Atomic Time reference (effectively 'zero drift'). The RFS (CH1), otoh, can and will drift even if that drift is some 2 or 3 orders of magnitude less than a typical OXCO, hence the need to calibrate it against a World Atomic Clock derived standard such as that offered by the GPS system.
