You could be right about the satellites. I can't receive any at all with a puck antenna even on the window sill. My active outdoor antenna is mounted on the house wall facing east and usually sees 10-12 satellites.
A GPS patch antenna should always be facing up, or close to up or be pointing at the clear patch of sky -with an elevation mask set! the elevation mask will then reject odd order reflections, which are polarity reversed.
An elevation mask is always a good idea with a patch antenna.
Also, it sounds like you may be using it without a ground plane. A patch antenna doesnt work properly without a flat piece of metal beneath it. Ideally it should be aligned with the horizon, really.
Thats an integral art of the antenna. It doesnt responate properly without it. At the minimum you should use something like a junk CDRom or ideally a piece of steel the magnet can adhere to. A piece of PCB will do fine too. The bigger it is the better it will work! I also put a small ferrite on the coax coming from them to decouple the feedline. That usually makes a small but meaningful improvement in the pattern.
I recently got a NanoVNA and its obvious when sweeping the passinve GPS antennas I have why the groundplane is essential and why it should be larger. They clearly come from the factory tuned to a large GP, like the roof of a car. There is a very noticeable dip at the resonant frequency and if you use a passive GPS antenna with the factory's minimal ground plane you can see how radically it shifts with a small versus large ground plane.
They come just as the ceramic element with a peg, to connect it, the equivaent of having an antenna supplied just as a whip, and a PCB pattern, the device, not the antenna - manufacturer ususally provides their own PCB and it is the groundplane.
Basically, the groundplane makes the antenna. So you cant just put a puck antenna on your windowsill and expect it to work. What I would do is take a junk CG and using any available means, attach that to your puck's bottomside. They are cupposed to magnetically affix to an automobile roof. Thats how they are supposed to be used.
But just a CD/DVD will give you just enough GP to get it to work. A bit larger would be better. 20 cm or more, several wavelengths, would be ideal if its practical. It will improve your performance a lot. Anything flat and conductive will do it. Put some copper tape on your windowsill.
A lot of people make this mistake. The same appllies in any rover, UAV, etc. situation.
