Thanks
imo,
It seems that every time I run a test, TL produces different curves I can't explain. I'm getting frustrated and annoyed.
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
The updated chart shows that. Both IsoTemp plots were made under exactly the same conditions, one day apart. The green trace is the latest. Seems too big of a variance to me.
I'm afraid now that I'm hi-jacking this thread with my issues, but on the other hand, other newbies could potentially run into the same situation.
I considered starting a new thread, but this is so closely linked to the Lars GPSDO method of measuring the DAC results with TL that I decided against it. I hope I'm being excused.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
I apologize up front though.
I ran a new TC4 test for the CTI, properly warmed-up for a few days in the enclosure and during the night (no disturbances).
At the same time, I also ran a TC4 test for the IsoTemp, properly warmed-up for several hours, in a bubble-wrap bag and also during the night. (don't have another enclosure yet)
The TC4 tests are described on page 11-12 from Lars' documents, and I used the second method to find the optimum TC.
Below are the combined results.
It seems that after warming-up, the CTI results are a little worse compared to the first plot. You would think that it would be better.
Although I'm easily running the CTI with a TC of 500, the MDEV plot seems to indicate an optimum TC of about 200 for both. Two hundred seems to be pretty poor.
The MDEV plot seems to indicate that the TempTech OCXO (bottoms at 1.37E-11) is not as good compared to the CTI which bottoms at 7.05E-11.
However, from Lars' comments on page 12, the sharp upward trend after bottoming out for the CTI indicates that it has a lot of drift.
The frequency plot shows no serious frequency jumps, but this plot also seems to indicate that the IsoTemp has a lot more noise/jitter compared to the CTI, which is much more stable. This to me seems to contradict with Lars' comment about drift on the MDEV plot.
What does the wriggle in the curve of the IsoTemp show after 4.000 seconds? What does that mean?
So can you infer the better OCXO by using the TC4 measurement results and if so, which is the better OCXO and what TL plot determines that?
