1. The layout guidelines for the TDC7200 suggest adding series resistors into the SPI lines. I've provided them, but I won't really need them if the layout is tight and the traces just a couple of millimeters, will I?
2. Another recommendation is to have matched length START and STOP inputs. I think that's not relevant in my case, it will just skew the phase of the 10MHz against the 1PPS signal a little bit.
3. I'm using a MC7805 for creating an 5V supply for the DAC and the Opamp (VDDA), with an added LC filter. Is that sensible?
1. I would let the resistor's there. They limit EMI between those two chips as well (the 22ohm in 500kHz? - nope, the 22ohm should be put in all SPI lines).
2. do it as best as you can.. I would split the "10MHz" via 2xinverters into "10MHz for 390" and "10MHz for 7200".
3. LC filter is ok, even 100nH is rather on the lower side (1-10uH would be better, imho). Add 10-22uF MLCC into VDDA.
7805 - stability - the DAC has got its own 2.5V 2ppm/C Vref, afaik.
Critical are the R6/R7 - their TC. If you use 50ppm/C resistors the TC of the gain could be 100ppm/C easily.
Also doublecheck the TC of the TLC272 input offset (1.8uV/C).. I would create a VDDA1 for the opamp. And from opamp's output an RC low pass, like 100ohm and 10n.
7404 input 10MHz squarer (fed by 1-2Vpp sine) - that is also a critical component (jitter). Such a simple solution does not work well usually.
I would put an inverter into 1PPS as well, but not from the same package as the 10MHz ones (there are 5pin smd 74xx inverters/buffers available).
I would also add a capacitor at the input of the 7805. Also a serial diode into the 24V rail.
Provided your system will take 40mA @5V the power loss at the 7805 will be 0.8W with 24V..
You are missing one important component of the GPSDO - "Locked" LED ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
I added the resistors in the start/stop signals because the sample layout from the datasheet has them, I guess I'll keep them as well, I can always replace them with a 0R bridge.
Regarding the input sine-to-square, I took that circuit from the LPRO-101 user guide. They use a 74AC04, however. There's also a variant with a 1:1 voltage divider at the input of the inverter and without the feedback resistor for self balancing, would that be better? The data they provide for phase noise seem ok, < -150dBc @100kHz, < -100dBc @1Hz. They describe a variant with a high-speed comparator as well (LT1016) but the phase noise is worse.
I'd rather not add an inverter in the 1PPS signal, the TDC manual says it's best to use the rising edge for both start and stop, also the 1PPS signal will anyway be quite jittery, so I'd rather take it as it is and not add another jitter source. The PLL in the MCU will have to deal with the original jitter anyway.
Regarding R6/R7 - I can use 25ppm or better there. Not a problem, resistors are cheap, even with 25ppm TC. 10ppm gets you into 0.5€ in single quantities, but they're readily available, too. I don't think I'll use trimmers here. They definitely have a worse TC than a precision SMD resistor. If I want to change voltage, I'd rather change resistors.
The opamp is actually a TLC2272A, but the offset voltage TC isn't any better, still in the 2µV/°C range.
Still, on the topic of temperature stability, wouldn't the control loop eventually correct the offset? Of course there will be a drift while the temperature changes, but if it happens slowly, the control loop will be able to keep up and stay in lock. It's important for the hold-over case of course, but then an active temperature compensation will be necessary anyway. The STM32 has a built-in temperature sensor, maybe it's good enough for that.
Regarding the power dissipation of the 7805 - I'm using a DPAK package and there will be ample copper for cooling. The variant I chose has a TC of -0.3mV/°C
However, I'm going to change that to a 12V type and rather provide separate point-of-load regulators for the digital and the analog parts, instead of trying to decouple the domains via an LC filter.
Single circuit inverters - there's indeed a lot of them available. But most of them have Schmitt trigger inputs, would that be a problem?
The 24V supply will be taken from another project of mine, I already have a small PCB for the LPRO with overvoltage and reverse polarity protection, I will reuse that circuit.
BTW, the LPRO-101 has a trimming range of around 3 ppb over 5V, or 0.006Hz/V. I don't think I'll be in trouble for this particular use case. But the design should be versatile enough to support a standard OCXO, too, with only BOM changes.
