I feel a little guilty to haven’t answered PM’s and probably will not do but instead do some general comments here. As I said my health is not well – frankly I am suffering cancer and treatments are tough. So for a long time I haven’t done something to my GPSDO project.
My LPRO rubidium based GPSDO is on all time and a little sporadic I check it. It is still very stable and due to the internal data logging up to 18 days (every third hour) I can follow the drift of the LPRO. So after 5-6 years I can see drifts below 1E-13/day (averaged over long times).
One question is if I have an updated software and the answer is no. Actually I have not found or heard of any bug so severe that I have had a reason to do any changes. I have a long list of improvements but as testing is so important I would like to have a very good reason to do changes.
Some ask about LCD and my answer is again about robustness and also that it is so many different GPS module so I recommend adding the display to a separate processor that also reads the GPSDO controllers serial line. Others ask about changing components but again robustness. Some ask about changing processor but that is really something for everybody interested in experimenting except me.
Back in March I was a little bit better and decided to start two of my OCXO based GPSDO’s to get more data and charts as I had seen a lot of more or less strange comment in other GPSDO thread here on EEVblog. I decided to take two GPDO that I know had OCXO’s with a lot of retrace, so not the best. One OCXO with about +10ppm retrace for a month and the other with -10ppm instead. Both OCXO were STP2187 double oven from eBay. I also had seen that at least one of them had jumps in the E-10 range even if with days or longer between.
As the Trimble thunderbolt is very admired by time-nuts I decided to setup the OCXO time constants to give about the same ADEVs as a non-optimized thunderbolt with TC 100 seconds. That is to give an ADEV at about 1E-11 at 100 sec. This also gives the frequency accuracy as I see from e.g. the leapsecond .com tests that give frequency stabilities and accuracies of about 1E-10.
http://www.leapsecond.com/pages/tbolt-tc/ http://www.leapsecond.com/pages/tbolt-8d/As my GPSDO is not as good as the thunderbolt I chose 200s TC, so settling time will be about twice as long is my guess. One of my GPSDO’s had a NEO 6M and the other an LEA6T (timing receiver) as the LEA can be set for position mode I tried that first. This also showed that the ADEVs at 100 seconds were similar and at about 1E-11 for both the NEO and LEA. With a good survey and timing mode it was possible to get ADEVs in the higher -12 range, maybe a factor of two better for the LEA.
One of the things I wanted to test was how long time does it take to get the frequency accuracy in this case. My goal were 1E-10. After about 30 minutes both GPSDO were within 1E-10 measured with a TAPR TICC versus the rubidium GPSDO. It took about an hour to get the locked LED ON. This shows the conservative locked spec in the Arduino program but I prefer this instead of the other way. As the locked condition requires the phase/time to be within 100ns (low pass filtered with 16 seconds) for at least 5 time constants this means that the frequency should be within 100ns/200secs * 5 that is 1E-10 so on par with my goal of 1E-10 in this case. But if you look on a PI-loop with the damping I have set, that also corresponds to the default setting of the Thunderbolt it will converge in a smooth manner that gives better results. I have had that it is a drawback to have just one time constant and no switching of time constant or FLL locking in the beginning but I am not sure it is really a problem from a settling time point either. Having just one time constant and the classic third order PI-loop are very robust in my opinion. Having seen comments on time nuts with HP 38xx GPSDO’s giving strange results after jumps also gives these conclusions as a jump recovers nice on my design.
During the month I had the GPSDO’s on I had one jump that were enough large to turn off the locked LED. As I said the locked LED requires the time to be within 100ns. If the OCXO jumps 2E-10 and the time constant is 200seconds the loop will go away just below 100ns so the jump was above 2E-10.
I also had another occasion with the locked LED off that I traced to the signal from the PPS but don’t know if it were the GPS module or antenna. I should say I at both of these occurrences had a terminal program that logged the output of the GPSDO serial line otherwise I only afterwards could have seen from the logged 18 days data that the GPSDO were unlocked during 3 hours.
Lars
