Well
imo thank you for clearing this up!
This column or numeric field selection in TimeLab is mighty confusing for new players, like me.
If you look at figure 6 on page 18 of the Lars document, you can see that he used Numeric Field # 3 when he collected live serial data. That is also what I used when I collected live serial data. When I switched to importing the data from a CSV file, it all went to hell because in this mode, TimeLab treats the Numeric Field information differently and I continued to use field number 3, and that was my trap. Or is it a TimeLab ambush?
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
When you're dealing with the Arduino Serial Monitor, the columns are very well defined.
When you import them into Excel, the individual columns are put into individual cells.
When you export the Excel file to a CSV file, the individual cells are separated by either a "," or ";" depending on your country setting I believe.
All intuitive, universally understood and simple and Timelab in the live collection mode works the same way.
The following is my understanding of what I did wrong in the importing mode and gathered with your help.
First of all, I assumed the correct field based on the live mode and also CSV fields and never looked at the explanation that is in the attached file. My bad.
When you import the CSV file (=data from ASCII file) into TimeLab, it does not understand the CSV format.
It puts everything beginning with a
+ - . or [0-9] into a field. The field separation can be
any other character.
In my case, I imported this into Timelab:
11:26:16.279 -> 72470;6;32905;51,9;Locked;-18;1848;500;250;
Using the Arduino/Excel/CSV format, the DAC value is in the third field. and that is what I used all along with all my import measurements.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
If I now understand it correctly, TimeLab creates the following
numeric fields from my CVS file:
1: 11:26:16.279
discarded "->"
2: 72470
3: ;
4: 6
5: ;
6: 32905 <== the one we need
7: ;
8: 51,9 (note that this notation is due to my country setting. It can also be a period "." as the decimal separator)
9: ;
Discarded "Locked"
10: ;
Etc.
EDIT Nope, still got it wrong, see
imo's explanation below.
Is my understanding (and explanation for other young players) correct?
