Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
LAB techniuque to avoid higher current then possible
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LAB techniuque to avoid higher current then possible (Read 215 times)
john23
Regular Contributor
Country:
on:
September 21, 2024, 01:48:59 pm »
Hello,I have build a circuit which intend to use as a driver for PMA5-83-2W+.
My main concern is the driver putting more current then the port can handle.
For example in my circuit shown in the attached photo I have TL431 which can output much more then 4mA.
So In the worst scenario my circuit will see 100Ohm instead of 555Ohm and I will get much higher current flowing into the Vg1 port and damaging it.
Is there a way to handle it in the lab?
Thanks.
LTSPICE file are attached.
https://www.minicircuits.com/pdfs/PMA5-83-2W+.pdf
Last Edit: September 21, 2024, 01:53:18 pm by john23
Logged
NiHaoMike
Super Contributor
Country:
"Don't turn it on - Take it apart!"
Re: LAB techniuque to avoid higher current then possible
Reply #1 on:
September 22, 2024, 01:45:07 am »
I'm not understanding the problem, the TL431 cannot supply any current, it can only sink it. The current supply is from the opamp which is limited by the resistor.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
