Hi all,
I'd like some advice on my project. I have an FT2232H with port A connected to an FPGA for 245 sync operation and port B as an RS232 interface for communicating with and programming an ESP32. Port A have been preconfigured in the EEPROM for the sync mode using the D2XX driver and port B as RS232 and VCP. Both interfaces work perfectly well independently however when I connect to and configure port A using the D2XX driver, port B stops working with no communication and it's not possible to program the ESP32 unless I power cycle the FT2232H putting it back into the EEPROM configuration. When I do configure and use port A using D2XX this works as expected.
Does anyone have any experience doing this kind of thing? I have tested this setup on MacOS and Ubuntu with the same results. I'm confident I'm configuring the correct port otherwise I wouldn't get any data from the FPGA. Below is my init code.
Thanks!
dev_serial = "SE9AJ5P8A"
print(f"Connecting to {dev_serial}")
dev = ftd2xx.openEx(dev_serial.encode(), ftd2xx.defines.OPEN_BY_SERIAL_NUMBER)
time.sleep(0.1)
dev.setTimeouts(10, 10)
time.sleep(0.1)
dev.setBitMode(0xFF, 0x00)
time.sleep(0.1)
dev.setBitMode(0xFF, 0x40)
time.sleep(0.1)
dev.setUSBParameters(0x10000, 0x10000)
time.sleep(0.1)
dev.setLatencyTimer(2)
time.sleep(0.1)
dev.setFlowControl(ftd2xx.defines.FLOW_RTS_CTS, 0, 0)
time.sleep(0.1)
dev.purge(ftd2xx.defines.PURGE_RX)
time.sleep(0.1)
dev.purge(ftd2xx.defines.PURGE_TX)
time.sleep(0.1)
