Look, I have placed all of your questions in one place for reference.
The truth is that what you are asking about is so far beyond your level of understanding and capability, that even if an answer was provided it would not help you.
The best advice for you is to stop asking about how to generate an AC magnetic field, and instead try explaining what it is you hope to do with it, if somehow you were to succeed?
Tell us your goals. Tell us what problem you are trying to solve?
I am trying to create a circuit that can generates AC magnetic fields in two pairs of helmholtz coils. How can I best do this and could you include schematics from a place like falstad?
I added a little more info: I have two pairs of helmholtz coils that I want to generate ac magnetic fields of for example 0.01 T
one pair with a radius of 2 cm and another with 1 cm
I am trying to create an ac field
10 hertz
20 coils
.1 cm wire
i have 9v dc battery
I need an amplifier that can amplify the signal from a function generator to create an ac electromagnet
I need an amplifier that can amplify the signal from a function generator to create an ac electromagnetic field in two pairs of helmholtz coils
any suggesetions? preferably something cheap
How can I convert the amplified voltage here to current? I am trying to create an ac magnetic field using a function generator
