Author Topic: Keithley 2302/3/4/6 inexpensive 8-pin terminal block  (Read 1435 times)
Offline rastroTopic starter
« on: September 28, 2016, 10:26:27 pm »
I found some inexpensive 8-pin terminal blocks for Keithley Power supply 2303/4 & Battery simulator 2306/2.
They do not have the screw attachments but still fit snugly to the instrument and only cost $1.00 :-+  I seems the Keithley connectors are little more expensive.
I picked these up at tayda electronics.
http://www.taydaelectronics.com/connectors-sockets/terminal-blocks/pluggable/8-pin-female-plug-in-type-vertical-terminal-block-5mm-5esdv.html
It looks like digikey has a similar connector with screws for ~$3.00.  I have not verified the fit on these.
https://www.digikey.com/product-detail/en/amphenol-fci/20020002-H081B01LF/609-4225-ND/2509295
-rastro
« Last Edit: September 28, 2016, 10:29:22 pm by rastro »
