Author Topic: Jellybean SMD Diode  (Read 4914 times)
Offline Sam__Topic starter
Jellybean SMD Diode
« on: May 24, 2014, 08:25:29 pm »
Just wondering what people around here use for low current (>1A) jellybean smd diodes? Looking for something to make a voltage doubler with and trying to avoid through hole.
Offline fcb
    • Electron Plus
Re: Jellybean SMD Diode
« Reply #1 on: May 24, 2014, 08:41:26 pm »
BAS16 (100mA)
GS1A (1A)
SS310 (3A schottky)
These are my goto parts.
Offline mariush
« Reply #2 on: May 24, 2014, 08:47:28 pm »
http://uk.farnell.com/diodes-small-signal
http://uk.farnell.com/diodes-schottky
http://uk.farnell.com/diodes-rectifiers
Check in stock, check exclude extended range, apply. Sort by price then pick whatever you see smd and available in large enough volume and doesn't require you to buy 2500pcs at a time.
Knock yourself out.
« Reply #3 on: May 24, 2014, 08:48:59 pm »
Thanks a lot guys :)
Offline Bored@Work
« Reply #4 on: May 24, 2014, 08:55:37 pm »
BAW78 (also as dual diode). MBRS and MURS series, like MBRS120, MURS120. Zetex S1 series.
Offline theatrus
« Reply #5 on: May 24, 2014, 09:36:26 pm »
B360A is my goto on the schottky.
Software by day, hardware by night; blueAcro.com
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: May 24, 2014, 10:39:46 pm »
Not very specific, so take your pick...
In order of current capacity, high speed junction / schottky types.
BAT54 (A, C, S suffixes) (SOT-23, SOD-323, etc.)
BAV99 (~dual 4148, SOT-23)
MMSD4148W  (and other prefixes for various sizes: SOD-123, 323, MELF, etc.)
MBR0540 (SOD-123, etc.)
MBR160 / B160 (anything from 130-1100 for different breakdown voltages; SMA)
ES1B (and other suffixes for different voltages; SMA)
B340 (SMB)
ES3B (SMC)
B540 (SMC)
and so on.  Bigger devices are available in D[2]PAK and such but really, by the time you're over 5A schottky / 3A junction, you need a heatsink.
Seven Transistor Labs, LLC
Offline Evil Lurker
« Reply #7 on: May 25, 2014, 04:57:52 am »
I'm guessing for a simple voltage doubler some M4's or M7's would do the trick.
Offline TMM
« Reply #8 on: May 25, 2014, 05:07:46 am »
using BAT54 and BAW56 here.
Edit: saw you need >1A
« Last Edit: May 25, 2014, 05:11:18 am by TMM »
Offline poorchava
  • Troll Cave Electronics!
« Reply #9 on: May 25, 2014, 08:17:07 am »
for small currents BAT54 (all variants), BAV99 and 1N4148.
For bigger currents SK and SS series.
« Reply #10 on: May 25, 2014, 10:22:58 am »
So many options! That's so much. Ordered some BAT54's, will see how they do the job.
Thanks again.
