Author Topic: Switch spark on turn on  (Read 1229 times)
Offline laejfTopic starter
« on: December 30, 2020, 10:21:59 pm »
How do I avoid sparking in my cheap slide-switch when I turn on the circuit? Is it a sign of too large capacitance? It does not spark when turned off.
1142188-0
Offline bob91343
Re: Switch spark on turn on
« Reply #1 on: December 30, 2020, 10:26:26 pm »
The problem is that C1 draws a lot of current when you connect power to it.  You can add an inductor in series with the switch but then you may have sparks when you switch it off.  Add a resistor if you can afford the voltage drop.
« Reply #2 on: December 30, 2020, 10:33:53 pm »
Perhaps a charge resistor for the cap with a parallel discharge diode? Never seen that being used really so perhaps there are more elegant solutions. Thanks
Offline bob91343
« Reply #3 on: December 30, 2020, 10:47:35 pm »
That won't work.  The capacitor needs to charge and discharge frequently so a diode will not allow that.  A series resistor will destroy the capacitor's function; it needs to be low impedance.
Offline jaycee
« Reply #4 on: January 03, 2021, 02:41:02 pm »
Do exactly what you would do to spark suppress a relay. Put an R-C snubber across the switch terminals.
Offline S. Petrukhin
  • Country: ru
« Reply #5 on: January 03, 2021, 02:46:24 pm »
The damper does not save from the charging current of the capacitor. :)
And sorry for my English.
Offline jananetha
  • Country: in
« Reply #6 on: January 05, 2021, 08:34:06 am »
Finally what is the best method to suppress the sparks
Online Zero999
  • 0999
« Reply #7 on: January 05, 2021, 10:40:41 am »
(Attachment Link)
As you've said, it's a sign of too larger capacitance. The data sheet for the LM1117 shows a 10µF, on the input, and you are using 470µF.
https://www.ti.com/lit/ds/symlink/lm1117.pdf
Why are you using 470µF, rather than 10µF? If it's powered from a power supply, with a lot of ripple, such as rectified mains frequency AC, then put the switch between C1 and your circuit and use another, lower value capacitor, right next to U5 and U6. If the wires to the switch are short, you can use an even smaller capacitor than 10µF.
« Reply #8 on: January 05, 2021, 12:16:26 pm »
I thought that it couldn't hurt having a large tank-capacitance, especially for the DC-motor/pump. The power supply has a bit of ripple, but I could try a smaller capacitor. Thanks!
« Reply #9 on: January 05, 2021, 12:30:21 pm »
I replaced the 470u cap with a 10u and now there is no sparking!
Thank you for the help!
