I blew up an ESP32 Devboard connected to a 12v PSU recently, just got a new ESP32 in the mail, went to test it and no power. Went to check the inline fuse that I installed... Well isn't this interesting...
You can see the case for the fuse is all warped. Might think that a fuse labelled F1AL250V would blow before warping the plastic? Unsure if the fuse did actually blow, as when I went to pull the fuse out, it shattered into many pieces.
Edit: should have been a 200mA fuse, thats likely what caused this
