Author Topic: jay diddy 5 transistor esr meter  (Read 29867 times)
Offline pete gTopic starter
« on: April 30, 2016, 08:21:43 pm »
hi all, greetings from s. florida. I just completed the 5 transistor esr meter project. need some help to determine if its working right. at turn on the meter goes all the way to the right. when I short the probes the meter does not go all the way to the left. when I scope the output, I get a square wave at 94khz, vpp of 90mv. has anyone else built this project? should the meter go to the right without shorting the output? I posted this in test equiptment by mistake.
Online EntropyWizard
    • GitHub
Re: jay diddy 5 transistor esr meter
« Reply #1 on: May 01, 2016, 01:43:49 am »
Something went wrong. The meter should hold near the left origin. You can use the zero adjust on the meter face to calibrate the left mark (open circuit). When you short the terminals, it should move all the way to the right-most mark. You can calibrate the right zero (0 ohms) with the pot that is specified in the circuit.
« Last Edit: May 01, 2016, 04:34:21 am by entwiz »
« Reply #2 on: May 01, 2016, 12:19:13 pm »
hi, thanks for your response. I made the smd version, I checked the board, looks ok, the problem must be in the meter circuit? any ideas?
Offline Bryan
« Reply #3 on: May 02, 2016, 10:32:58 am »
Well other than the obvious, shorts, opens, defective components. I assume the PCB design has been tested by others and is correct by the schematic.
-=Bryan=-
« Reply #4 on: May 02, 2016, 12:52:33 pm »
hi bryan, to answer your question, I don't know. i'am curious as to whether this design has been proven out by someone. from what I can see, it appears the osc signal is always present at the meter, thus the full scale deflection. I verified this by scoping the signal.
Offline dannyf
« Reply #5 on: May 02, 2016, 08:14:42 pm »
With the probes open, the meter should not move at all, at its left most position.
With the probes shorted, the meter should go to the right.
« Reply #6 on: May 02, 2016, 09:45:47 pm »
hi dannyf, thanks for the info. is it possible for you to trace the osc sig with the probes open and shorted?  then I might have a shot at fixing this project. since its smd, knowing exactly whats wrong will spare the pcb. thanks.
Offline dannyf
« Reply #7 on: May 02, 2016, 10:37:20 pm »
I don't know what that means.
If I were to debug it, I would make sure that a) the oscillator is working, and b) the dc working points make sense. and go from there.
« Reply #8 on: May 02, 2016, 11:22:09 pm »
hi danny, in my first post I stated that the osc is indeed working. i'am getting a 94khz square wave at vpp of 90mv, this at the probes. the dc is a rock solid 5v. whats not working is the metering half of the ciecuit. i'am not asking you to debug, only to provide some assistance.
« Reply #9 on: May 02, 2016, 11:27:13 pm »
as far as the tracing of the signal, I meant a verbal explanation of the sig flo.
Offline dannyf
« Reply #10 on: May 03, 2016, 12:31:48 am »
It is fairly simple: an oscillator, through a driver stage, drives a resistor in serial with ESR. The signal over the ESR is amplified by a differential amplifier and the rectified portion goes through the meter.
It is fairly complicated for what it does.
Offline dannyf
« Reply #11 on: May 03, 2016, 12:51:53 am »
So the oscillator + the driver are working.
You should establish that the DC working points are correct first. Otherwise, you get nothing to work with.
« Reply #12 on: May 03, 2016, 01:20:58 am »
hi dannyf, I think I found an error on the picture that shows the parts on the board. there is a resistor marked RB that should be R8 the value on the schematic shows this resistor value as 150 ohms. it should be 1500 ohms. is this correct?
Offline dannyf
« Reply #13 on: May 03, 2016, 11:59:19 am »
I don't know what/which schematic you are referring to.
If you suspect its value is incorrect, parallel a 150ohm resistor to it and see if it works.
« Reply #14 on: May 03, 2016, 04:51:45 pm »
false alarm, although the value of that resistor has an effect, its not the problem. I misread the resistor (smd) 1500 is 150 ohm. rats!
Online Jay_Diddy_B
« Reply #15 on: May 03, 2016, 10:35:39 pm »
pete g and the group,
I know a thing or two about this circuit. I have been away from my a laptop for a few days, but I am back now. I will post some waveforms, which should help with the troubleshooting.
Several people have built this circuit successfully.
Regards,
Jay_Diddy_B
Offline dannyf
« Reply #16 on: May 04, 2016, 12:22:42 am »
I obviously don't know what the problem(s) here are. But the issue with the design is that the rectifier is open loop. As such, if there is too much attenuation of the oscillator signal, the meter reading is quite non responsive - a sharp drop off.
the way it is attacked here is to use more gain. A better solution is to get the rectifier into the feedback loop.
« Reply #17 on: May 04, 2016, 01:03:34 am »
checked some voltages. with the leads open q4 & q5 are conducting. .6 forward bias, collectors at 1/2 b plus (2.5v) if I turn off q4 the meter goes all the way to the left.
Offline dannyf
« Reply #18 on: May 04, 2016, 02:01:49 am »
'checked some voltages. with the leads open q4 & q5 are conducting. .6 forward bias, collectors at 1/2 b plus (2.5v) if I turn off q4 the meter goes all the way to the left.'
I think you can benefit greatly by being concise. Without a schematic, no one knows what q4 or q5 is. Telling tour readers what vbe is tells them far less than if you told them what VB is and what ve is....
Right now,you are saying a lot without being informative. It helps if it is the other way around. Posting a schematic with the DC working points in it will tell your readers far more than all you have said so far.
Hope it helps.
« Reply #19 on: May 04, 2016, 02:28:07 am »
well the problem is. is that there are no voltages on the schematic. i'am really surprised you don"t remember this project as you were a fairly prolific contributor to the thread. I think the schematic can be had the same way I got it and that is search on this website for the 5 transistor jay diddy b esr meter. I thought that would be fairly obvious.
Offline Bryan
« Reply #20 on: May 04, 2016, 05:58:59 am »
Yes, but there was a number of revisions and different schematics, PCB designs posted, some tested some not. Which one did YOU use.
-=Bryan=-
Online Jay_Diddy_B
« Reply #21 on: May 04, 2016, 07:53:40 am »
Hi group,
I have had some time to take some measurements in the lab.
These measurements were taken from the unit described in this thread:
https://www.eevblog.com/forum/projects/5-transistor-esr-meter-design/msg171364/#msg171364
The schematic is reproduced here:
I have added the dc voltages. These voltages were measured with a Fluke 187.
The input terminals were open circuit for all measurements and scope waveforms.
Waveforms
Q3 collector voltage:
This waveform should swing from rail to rail. The average voltage should be approximately half of the supply, 2.5V. The frequency is nominally 100kHz.
TP1 Waveform
This waveform should be the voltage on Q3 collector time 3 / (150 +3) = 98mV p-p
Q4 Base Voltage
The average voltage should be 5v(10K/(10K +27K) = 1.35V
Q4 Collector Voltage
Q5 Base Voltage
Q5 Base voltage is the same as Q4 Base voltage
Q5 Collector
The voltage on Q5 Collector is the same as the voltage on Q4 collector when the input is open.
Q4 Base (AC Coupled)
Q4 Collector AC coupled
These waveforms and voltages should help you troubleshoot the circuit.
Regards,
Jay_Diddy_B
« Last Edit: May 04, 2016, 07:55:54 am by Jay_Diddy_B »
The following users thanked this post: old-jo
Offline dannyf
« Reply #22 on: May 04, 2016, 10:24:38 am »
The driver should output a near 5vpp square wave. So the probe, when open, should show about 90mvpp.
The bases of the two amplifiers sit at 1.4v, and their emitters at 0.7v, and their collectors at 2.2v. All vs. Ground.
Anything materially different from that suggests troubles.
« Reply #23 on: May 04, 2016, 04:15:23 pm »
wow!! this is great. my question is, if the signal is getting to the meter with the probes open circuited, what keeps the meter from deflecting?
Offline dannyf
« Reply #24 on: May 04, 2016, 06:40:17 pm »
It is a bridge configuration. One arm of the bridge has fixed attenuation and another has its attenuation varying based on the duts ESR.
If the proves are open, the same unattenuated signal will show up on the meter - it is not going to move at all.
The biggest meter movements come when the difference between attenuation is the biggest - when the probe is shorted.
