Made a few pictures of this Chinese module. I intended to build a simple HV lab supply with this, but finally just got a real (Chinese) one.
Scope shot is from switch node. Some really strange switching here, does not look as if the UC3843A does what it is supposed to do.
Also as mentioned earlier not the lowest noise option one might imagine. Bipolar output with center tapped secondary is a nice bonus. Even somewhat regulated due to flyback connection.
Here
https://impulsite.ru/viewtopic.php?t=1294#p23960 you can find the schematic. Googling for yh11068a will give you many more hits.
If you read the whole article from page 7 Jim Williams has a whole section on low noise flyback converters, difficult I agree, but obviously not impossible.
I have not memorized all of JW's writings. These examples are a bit more low power though.
I assume the TO will not need isolation. For an isolated supply, getting rid of CM noise is a whole different story (and much more difficult than filtering output ground referenced noise).
I'd probably start with the yh11068a module - if it's good enough, then that is hard to beat.
Next would be a current-fed resonant Royer (Baxandall), these are very easy to DIY and winding a transformer (N87 RM core, maybe RM10?) pretty easy.
Or a push-pull forward, maybe even fixed duty cycle? Depends on what regulation quality is required.
