What a coincidence, I just designed a very similar probe using the same chip!
My amplifier design differs from Wilson's in a few ways.
* He has a voltage divider in the HF and LF path... mine has just 1 divider. I'm not really sure why you would separate it into two, as that ostensibly creates an error term.
* I appeared to use a larger trimpot -- I couldn't find the smaller ones anywhere. But my compensation is all done in the lower-frequency composite loop, where the parasitics are less important.
* I filled/capped my vias, and added 5 under the amplifier (compared to what appears to only be 1 on Wilson's probe) so hopefully my amp runs a little cooler
* I added a USB C connector (because I have a million of them) and a buck-boost so I can power off my oscilloscope's USB port, or optionally a 9V battery
* I went with angled pogo pins that achieve ~1.4mm pitch at the DUT -- I figured this would work well for gate-to-source pin pitch on SO8 FETs, and also numerous passives.
* I ordered two different pin lengths that I plan to experiment with, which is why there appear to be 3 pins in the CAD.
* I also added a through-hole for a little mini-grabber ground lead in case I want to use that instead of two pins
I _really_ wanted to embed the pogo pins inside a slot in the PCB... but JLCPCB couldn't manufacture a thin enough slot for me so I ended up adding pads to solder them, like you did.
Mine should arrive from JLC in a few days! I have an SVA1032X and a Bode 100, so I should be able to characterize the response and will let you all know how it looks!
