Ho... surprised to didn't get more reaction from you
I'm currently porting the embedded code from Crossworks to an open ARM compiler toolchain (editing by Qt Creator).
The desktop command side is working on Visual Studio. need more time to understand the worflow on this side. between shape generator, simulator and server.
And later will work a BOM from my usual suppliers to get a supplier price.
Bots PCB is neat and seems to fit in the PCBPool technical constraints. But is done under Altium. I should port it under CircuitMaker to make it more Open compliant.
See you!
