That's a neat design. Is this effectively a bit bashed interface, i.e. the host software controls the low level programming protocol? Also does the isolated side work over the usual voltage signal range 3.3v to 5v?
Thank you mikerj.
I have used it industrial/harsh environments with 3.0, 3.3 and 5V targets on the isolation side without any problems.
Actually the Silicon Labs digital isolator IC has a voltage range of 2.5 V < VDD < 5.5.
It was not in the main target but it is also working nice with ESP8266 and Arduino stuff, direct programming, no more buttons to press or jumpers to set, smooth and fast programming
Programming software is on Host side. Basically you can see it as a transparent USB-to-Serial interface and you can even use it like that (Rx and Tx target Pins) for safe isolated communication with your target device.
When using as a programmer, if needed for your MCU (as ESP8266 needs for example), it brings the extra set/autoreset functions that will keeep you away from the hasle of setting jumpers and pressing buttons to go in the right BOOT mode for programming.
You can see here a
firmware upload example done on a Home Automation Dev Board with ESP8266:
Also, as a comparation, the same process with
a standard USB adapter
