A PCI-e card would work well if it had Linux drivers and wasn't too expensive..
Audio would be nice.. It is a major PITA to synchronize audio externally but I'm sure it can be done..
Would need something like those boards they use in movies.. "Lights, Camera, Action!" *Snap*
What do you want to do with the video? Do you need audio too?
Resolution?
Blackmagic's Intensity and Decklink have hdmi input. I've used a simple pci-e decklink with gstreamer in the past without much hassle to capture hdmi and sdi.
I have a USB2 device that accepts composite video - and it actually does a decent job digitizing it on a lightly loaded machine.. it was around $15 Its a easycap and it uses an stc60 chip, I think.. (from memory so I likely have that wrong) It has composite video and S-video inputs as well as a stereo audio input which isnt so good, its noisy.
Its meant for digitizing old video tapes.. for that it works fine..
Its resolution is around 640x480, and its an honest 640x480..
I think it came with the exact same yellow CD pictured in your video.. but its video looks better, even though its analog.
But HDMI is what I need, the camera I want to use supports HDMI.
