Author Topic: Gold plated outline Ground  (Read 1453 times)
Offline Nikos A.Topic starter
  • Country: cy
« on: January 03, 2019, 08:25:47 am »
Hi everyone and happy new year,
What is the purpose of this outline gold plated ground with vias fence?
Please see the attached picture
Thanks in advance
Nick
Offline ap
    • ab-precision
Re: Gold plated outline Ground
« Reply #1 on: January 03, 2019, 08:40:29 am »
Does not have to be gold plated, but is exposed side area, so here no solder mask, just the board with its plating surface. Purpose of via fence is mostly to keep the EMI generated internally inside the board and not radiate this through the edges.
Metrology and test gear and other stuff: www.ab-precision.com
  • Country: cy
« Reply #2 on: January 03, 2019, 10:41:46 am »
Thank you for the reply AP,
In that case I suppose that the plating surface is ENIG? (that's why the gold color?)
Offline deBug
    • ZachTek
« Reply #3 on: January 03, 2019, 06:38:43 pm »
Yes, looks like ENIG.
RF enthusiast. http://www.zachtek.com
Offline German_EE
« Reply #4 on: January 03, 2019, 06:51:51 pm »
Both a friend and I normally do this with our home made PCBs, it's a good way to ensure grounding to the case if you use one where the PCB just slots in, or it's a PCB case with the board soldered all the way around. For prototypes you can do the border with copper tape.
Warren Buffett
