Hi djococaud,
Hi !
What about a good old light bulb in series (100W) ?
Lights up if there is a short, but only usable on small loads though...
For one thing, light bulbs introduce a voltage drop during limiting which can destroy the circuit. In specific they will lower the voltage anywhere form 20-50%. If a switching mode power supply is operated with a voltage drop this high, it will try to make up low voltage with higher current, which will drop more voltage because of the light bulb, and eventually it'll self-destruct. To prevent this, you have to make the light bulbs provide much more power margin than is safe for a power supply in fault condition. However, if the light bulb limiter can offer so much current, then the power supply will be able to self-destruct during short circuit. So you're really trading off one self-destruct scenario for another.
A separated power supply with the right fuses will act better in that case. A lot of power supplies are smps nowadays.
On the other hand fuses + bulbs might work as well, except you need a very high margin between the power you want to deliver to your device normally, and the maximum power that your mains can deliver before tripping the fuse. That's an issue here.
