Author Topic: Mosfet as blocking diode-How?  (Read 33558 times)
Offline djsbTopic starter
« on: March 26, 2011, 11:27:01 am »
Someone at work mentioned they where using a MOSFET as a blocking diode. I think the application is solar cells. How is the Mosfet connected and how does it work in this config?
Thanks
David.
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Mosfet as blocking diode-How?
« Reply #1 on: March 26, 2011, 11:37:36 am »
maybe a P chanel mosfet ? perhaps with a voltage divider supplying the gate so that if the panels drop below a certainly voltage the mosfet is switched off. Or perhaps there is a full blown control circuit to triget it ?
Offline Simon
  • Global Moderator
« Reply #2 on: March 26, 2011, 12:32:42 pm »
You can get mosfets with no internal diode
Offline Zero999
  • 0999
« Reply #3 on: March 26, 2011, 12:47:13 pm »
You can't get MOSFETs without a diode.
When a MOSFET is used as a blocking diode, the internal diode is normally used, it's just bypassed by turning the MOSFET on, so the forward voltage is much lower.
Offline Simon
  • Global Moderator
« Reply #4 on: March 26, 2011, 12:48:54 pm »
oh right true I can't think of a part. I thought they were specificly built in.
There must be more than just a mosfet involved then to control it
Offline Zero999
  • 0999
« Reply #5 on: March 26, 2011, 02:03:27 pm »
Integrated SSR's for several amps start to get pricey for DC/AC. The one I linked to is $6 bucks or so and its only good for a couple of amps at 25C.
It's possible to make an SSR yourself but it's a totally different topic.
Online oPossum
« Reply #6 on: March 26, 2011, 03:01:26 pm »
Low drop rectifier using MOSFET and LTC4412
Note that the MOSFETs are connected "backwards" due to the internal parasitic diode.
« Last Edit: March 26, 2011, 03:08:58 pm by oPossum »
Offline Zero999
  • 0999
« Reply #7 on: March 26, 2011, 06:19:47 pm »
You only need one MOSFET, N-channel high side will do.
Drive to the gate can be provided using an oscillator and voltage doubler which is protected against reverse polarity by a normal diode.
I'll post the circuit when I've got more time.
Offline AdShea
« Reply #8 on: March 27, 2011, 01:23:02 am »
I've used P-Channel Fets as blocking diodes on MCU boards so they can write to EEPROM on power down.  The intrinsic diode on the FET forward biased when the board is initially powered.  Initially the gate is pulled high by a high-value resistor.  Once the chip boots, it pulls the gate low to reduce the drop when powering the rest of the board.  The MCU monitors the supply voltage.  If it drops below 4.5V, the MCU releases the gate.  If the supply doesn't return after a short time (a few ms), then the chip turns everything off and writes it EEPROM before the 100uF cap on board drops too far.
In this case, the P-FET is used as a diode which can be bypassed by the lower drop of a few mOhms of a fully enhanced FET.
Offline Zero999
  • 0999
« Reply #9 on: March 27, 2011, 08:55:13 pm »
Here's how an N-channel MOSFET can be used to provide high side polarity protection, it's a bit of a fiddle though.
Offline Simon
  • Global Moderator
« Reply #10 on: March 27, 2011, 09:13:51 pm »
so how does the mosfet stay on when the 555 switches low to charge the capacitor ? or does the gate capacitance of the mosfet sort that out (hence the 10M resistor) ?
Offline Zero999
  • 0999
« Reply #11 on: March 27, 2011, 09:56:24 pm »
Yes, the voltage doubler charges the gate capacitor. The 10M resistor discharges the gate capacitor when the power is disconnected.
Offline DrGeoff
    • AXT Systems
« Reply #12 on: March 27, 2011, 11:08:37 pm »
Mosfets have been used to replace diodes in high current switching applications that require a bridge rectifier without the 2Vf drop (and power/thermal issues that come with that).
http://www.thetaeng.com/FETBridge.htm
Was it really supposed to do that?
Offline scrat
« Reply #13 on: March 28, 2011, 12:35:51 pm »
Why shouldn't this work?
One machine can do the work of fifty ordinary men. No machine can do the work of one extraordinary man. - Elbert Hubbard
Online oPossum
« Reply #14 on: March 28, 2011, 03:58:39 pm »
It won't prevent the load from discharging into the source.
If the source is a PV panel and the load is a battery then it is useless. The MOSFET has to be switched on only when current can flow from source to load. A circuit using LTC4412 or similar chip will do that.
Offline Zero999
  • 0999
« Reply #15 on: March 28, 2011, 05:52:31 pm »
It will work if you can find a p-channel MOSFET with the internal diode connected anode to source (you won't).
Offline Leo Bodnar
« Reply #16 on: March 28, 2011, 06:04:18 pm »
There are quite a few ready-made ICs that when paired with external MOSFET create almost ideal diode.
Here are few examples:
http://www.farnell.com/datasheets/85443.pdf
 http://cds.linear.com/docs/Datasheet/4412fa.pdf
(internal MOSFET) http://www.farnell.com/datasheets/321107.pdf
E.g. google for "ideal diode controller" or suchlike.
Cheers
Leo
« Last Edit: March 28, 2011, 06:07:14 pm by Leo Bodnar »
Offline RayJones
    • Personal Website
« Reply #17 on: March 28, 2011, 08:02:24 pm »
Search for "Ideal Diode" on Linear Technology's website.
(edit: Whoops, that's what I get for posting from the bottom of page 1  :-\ )
« Last Edit: March 28, 2011, 08:04:20 pm by RayJones »
Offline scrat
« Reply #18 on: March 28, 2011, 09:35:23 pm »
I see, I was missing the "blocking" diode purpose. What I posted could be good for reverse polarity protection, not reverse current blocking.
If I think of an H-bridge high-side p-MOS, it has to have the diode connected that way...
However, I checked this, and it confirms the diode is connected as I have drawn (ex. see http://cache.freescale.com/files/analog/doc/train_ref_material/ANALOGPOWERICTR.pdf?WT_TYPE=Training%20Reference%20Material&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation).
Offline Jon Chandler
    • Throw Away PIC
« Reply #19 on: March 28, 2011, 10:02:07 pm »
Using a MOSFET for reverse polarity protection actually works pretty well.  If the MOSFET is carefully selected the voltage drop is minimal.  Either P-channel or N-channel MOSFETs may be used depending on where they are placed in the circuit.
This was discussed on the SparkFun forum sometime back.
I did some tests with a RadioShack MOSFET which wasn't the best choice but it definitely protects again reverse polarity.
See the entire thread here
Offline Zero999
  • 0999
« Reply #20 on: March 28, 2011, 10:04:54 pm »
None of the circuits with p-channel devices, in the paper you posted have the diode connected as per your schematic. All P-channel devices have the cathode connected to source and all N-channel devices have the anode connected to source.
Offline scrat
« Reply #21 on: March 28, 2011, 11:20:15 pm »
Oh... It' just that I've used your schematic (cut and paste on the image), and I didn't flip the MOSFET, since I'm not that familiar with p-channel (it's a little more rare). I just wrote explicitly "D" and "S" not to confuse... Sorry.
My circuit is the same as the second from Jon Chandler.
